    [HOTWORD:LPCM16] arecord: main:828 audio open error: Device or resource busy
    mmm-assistantmk2hotword
    7 Posts 3 Posters 3.3k Views 3 Watching
      M4gicD00bz
      Error:
      2020-04-26 15:48:17.583] [LOG]    [HOTWORD] Detector starts listening.
      [2020-04-26 15:48:17.701] [LOG]    [HOTWORD:LPCM16] arecord: main:828:
      [2020-04-26 15:48:17.703] [LOG]    [HOTWORD:LPCM16] audio open error: Device or resource busy
      [2020-04-26 15:48:17.706] [LOG]    [HOTWORD] Final Result: { detected: false }
      [2020-04-26 15:48:17.724] [LOG]    [HOTWORD] begins.
      [2020-04-26 15:48:17.726] [LOG]    [HOTWORD] Detector starts listening.
      [2020-04-26 15:48:17.808] [LOG]    [HOTWORD:LPCM16] arecord: main:828: audio open error: Device or resource busy
      arecord -I:
      @raspberrypi:~ $ arecord -l
      **** List of CAPTURE Hardware Devices ****
      card 0: sndrpigooglevoi [snd_rpi_googlevoicehat_soundcar], device 0: Google voiceHAT SoundCard HiFi voicehat-codec-0 [Google voiceHAT SoundCard HiFi voicehat-codec-0]
        Subdevices: 0/1
        Subdevice #0: subdevice #0
      card 1: Snowball [Blue Snowball], device 0: USB Audio [USB Audio]
        Subdevices: 0/1
      aplay -I:
      pi@raspberrypi:~ $ aplay -l
      **** List of PLAYBACK Hardware Devices ****
        Subdevices: 0/1
      .asoundrc:
      pcm.!default{
        type asym
        playback.pcm{
          type hw
          card 0
        capture.pcm{
          type plug
          slave.pcm "hw:1,0"
      ctl.!default{
        type hw
        card 0
      config.js:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			     // false, default for all  NON-armv6l devices
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "YOUR_OPENWEATHER_API_KEY"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "5128581",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
      			module: "MMM-Hotword",
      					chimeOnFinish: null,
      					mic: {
      							recordProgram: "arecord",
      							device: "plughw:0"
      					models: [
      								hotwords    : "smart_mirror",
      								file        : "smart_mirror.umdl",
      								sensitivity : "0.5",
      					commands: {
      							"smart_mirror": {
      									notificationExec: {
      											notification: "ASSISTANT_ACTIVATE",
      											payload: (detected, afterRecord) => {
      													return {profile:"default"}
      									restart:false,
      									afterRecordLimit:0
      		module: "MMM-AssistantMk2",
      				deviceLocation: {
      						coordinates: {
      								latitude: 37.5650168, // -90.0 - +90.0
      								longitude: 126.8491231, // -180.0 - +180.0
      				record: {
      						recordProgram : "arecord",
      						device        : "plughw:0",
      				notifications: {
      						ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
      						ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
      				useWelcomeMessage: "brief today",
      				profiles: {
      						"default" : {
      								lang: "en-US"
      • ? Offline
        A Former User
        what is the device used for recording mic ?
          sdetweil @M4gicD00bz
          @M4gicD00bz said in [HOTWORD:LPCM16] arecord: main:828 audio open error: Device or resource busy:
            					device: "plughw:0"
          but the asoundrc says hw:1,0 (which should be correct unless u are using the google voicehat, and have installed the software to enable it)
          should be device: “plughw:1,0”
          • ? Offline
            A Former User
            @sdetweil : that’s why i asked this question ;)
              sdetweil @Guest
              @Bugsounet it would never have been “plughw:0”, maybe “plughw:0,0”
              • ? Offline
                A Former User
                not necessary, it should be plughw:0, plughw:1 or null (for default setting)
                after, maybe one module use already the mic …
                in this case arecord return an error (device busy)
                  M4gicD00bz
                  I’ve tried every variation. I’ve scrapped everything. Starting from scratch again. I guess I’ll come back if still an issue.
