    Black Screen on start up on Windows
    2 Posts 1 Posters 385 Views 1 Watching
    • C Offline
      Chrisflex
      I get this screen again on both PC’s I have tried to install on.
      Once before I had this problem the fix was to delete
      Problem is now I can’t seem to find the correct place where this instruction is
      Below is the message I get.
      C:\Users\Dell Server>cd MagicMirror
      C:\Users\Dell Server\MagicMirror>npm start
      magicmirror@2.11.0 start C:\Users\Dell Server\MagicMirror
      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      ‘DISPLAY’ is not recognized as an internal or external command,
      operable program or batch file.
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.11.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.11.0 start script.
      npm ERR! C:\Users\Dell Server\AppData\Roaming\npm-cache_logs\2020-05-01T04_29_44_426Z-debug.log
      • C Offline
        Chrisflex
        Finally found it
        It resides in package.json
        Deleted the above
        " ./node_modules/.bin/electron js/electron.js"
        and it works
