    MMM-NewPIR only works if i plug/unplug the cable, but not without
    5 Posts 2 Posters 878 Views 2 Watching
    • F Offline
      feigi
      Hello everyone,
      My MagicMirror is working properly and now i am looking into the last detail, introducing a PIR Sensor for Motion Detection and safe energy on the Monitor if not needed.
      Now i configured the Module like this:
      module: ‘MMM-NewPIR’,
      position: ‘top_left’,
      useSensor: true,
      sensorPin: 23,
      reverseValue: false,
      delay: 20* 60 * 1000,
      turnOffDisplay: true,
      ecoMode: false,
      governor: “”,
      text: “Auto Turn Off Screen:”,
      counter: true,
      rpi4: false,
      debug: false
      The Time is running, after the entered time, the screen is getting turned off. That works properly. But the timer is actually only being reseted, when i unplug the cable on either the sensor or the raspberry pi.
      I only have one Sensor, i cannot exchange the Sensor.
      If i would enable debug to true, where would i find the output?
      Thank you very much for your support!
      Cheers,
      roman
      • ? Offline
        A Former User
        hi, what is your rpi type ?
        • F Offline
          feigi
          Hi there,
          Thanks for your quick answer.
          I do have a Raspberry Pi 3 Model B+
          • ? Offline
            A Former User
            ok, if you enable debug mode
            you have 2 solutions:
            1. manual start by npm start command in the ~MagicMirror directory
            2. if you use pm2 program. you can see log with pm2 log command
            note: if you MM is launched by pm2 don’t forget to stop it (pm2 stop 0) , if you launch MM in with npm start
            • F Offline
              feigi
              Hi there,
              The Sensor now works like a charm. But actually i am not sure what i changed, but since i enabled (and now again disabled) the Debug, it recognices every movement like intended.
              The Debug actually helped to see when it detects a movement, so that was indeed helpful.
              Thank you very much for the quick support!
              Best Regards,
              Roman
