    [npm library] @bugsounet/snowboy
    1 Posts 1 Posters 428 Views 1 Watching
    • ? Offline
      A Former User
      @bugsounet/snowboy
      I created this library if you want use snowboy in your module.
      This library is very simplified and ready for use in your node_helper.js
      This library is used in MMM-GoogleAssistant, MMM-Snowboy, MMM-AssistantMk2
      Dependencies
      For listening keyword, you have to use a mic, so snowboy need some dependencies to use it
      sudo apt install libmagic-dev libatlas-base-dev sox libsox-fmt-all build-essential
      Installation
      npm install @bugsounet/snowboy
      In the ending of installation, if you use electron you can do electron rebuild step.
      Do you want to execute electron rebuild ? [Y/n]
      Your choice:
      Sample with new Snowboy contructor
      /** sample code for using snowboy library **/
      /** @bugsounet **/
      const Snowboy = require("@bugsounet/snowboy").Snowboy
      var config = {
        debug: true,
        snowboy: {
          audioGain: 2.0,
          Frontend: true,
          Model: "jarvis",
          Sensitivity: null
        micConfig: {
          recorder: "arecord",
          device: "plughw:1",
      this.snowboy = new Snowboy(config.snowboy, config.micConfig, (detected) => { detect(detected) }, config.debug )
      this.snowboy.init()
      this.snowboy.start()
      function detect(detected) {
        console.log("Make your script if " + detected + " is detected")
      constructor of Snowboy
      Snowboy(snowboyConfig, micConfig, callback, debug)
      SnowboyConfig
      • AudioGain - set the gain of mic. Usually you don’t need to set or adjust this value.
      • Frontend - set pre-processing of hotword detection. When you use only snowboy and smart_mirror, false is better. But with other models, true is better to recognize.
      • Model - set the name of your detector. Available: “smart_mirror”, “jarvis”, “computer”, “snowboy”, “subex”, “neo_ya”, “hey_extreme”, “view_glass”
      • Sensitivity - Override default sensitivity value for applied model defined in Model.
        • Value could be within a range from 0.0 to 1.0.
        • Default sensitivity values for preconfigured models are:
          • smart_mirror: 0.5
          • jarvis: 0.7
          • computer: 0.6
          • snowboy: 0.5
          • subex: 0.6
          • neo_ya: 0.7
          • hey_extreme: 0.6
          • view_glass: 0.7
          • alexa: 0.6
        • null will set default sensitivity.
      micConfig
      • recorder - record program, rec, arecord, sox, parec is available.
        • On RaspberryPi or some linux machines, arecord is better.
        • On OSX, rec is better.
        • If you prefer to use pulse audio, parec would be available also.
      • device - recording device (microphone) name of your environment. (e.g. “plughw:1”)
        • Find proper device name by yourself. (arecord -l will be help on Raspberry Pi or linux platform)
      callback
      if snowboy detect a keyword, it return it with his name
      debug
      if you want debuging information, just set to true
      Functions
      • init() : initialize the constructor
      • start() : start listening and waiting for your keyword
      • stop() : force stop listening
