    [npm library] @bugsounet/governor
    1 Posts 1 Posters 249 Views 1 Watching
    • ? Offline
      A Former User
      @bugsounet/governor
      I created this library if you want to set a CPU governor in your module.
      This library is very simplified and ready for use in your node_helper.js
      This library is used in MMM-Assistant2Display
      single node routine for setting you prefered CPU governor
      Installation
      npm install @bugsounet/governor
      Sample with governor contructor
      const Governor = require("@bugsounet/governor")
      this.config = {
        useCallback: true,
        sleeping: "powersave",
        working: "ondemand"
      var debug = true
      this.governor = new Governor(this.config, callback, debug)
      this.governor.start()
      function callback(governor) {
        console.log(governor)
      constructor of governor
      Governor(governorConfig, callback, debug)
      governorConfig {}
      • useCallback- return callback confirmation (false by default)
      • sleeping- set your prefered governor on sleeping mode
      • working- set your prefered governor on working mode
      Available governor:
      • conservative
      • ondemand
      • userspace
      • powersave
      • performance
      callback {}
      callback return object with status:
        "actived" : true,
        "wanted" : "ondemand",
        "actual" : "ondemand",
        "error": null
      • actived: confirm with true if governor is set
      • wanted: your wanted governor to set
      • actual: your actual governor
      • error: display error if detected
      debug
      if you want debuging information, just set to true
      Functions
      • start() : start governor with working setting
      • working(): start governor with working setting
      • sleeping(): start governor with sleeping setting
