    [npm library] @bugsounet/cast
    1 Posts 1 Posters 278 Views 1 Watching
      A Former User
      @bugsounet/cast
      I created this library if you want to cast youtube in your module.
      This library is very simplified and ready for use in your node_helper.js
      This library is used in MMM-Assistant2Display
      single node routine for casting YouTube (or other ?) in webview tag
      Installation
      npm install @bugsounet/cast
      Sample with cast contructor
      const Cast = require("./index.js")
      this.config = {
        castName: "MagicMirror_Cast",
        port: 8569
      var debug = true
      this.cast= new Cast(this.config.cast, callback, debug)
      this.cast.start()
      setTimeout(() => { this.cast.stop() } , 30 * 1000)
      function callback(noti, castLink) {
        if (noti == "CAST_START") console.log("Open this link:", castLink)
        if (noti == "CAST_STOP") console.log ("Cast End")
      /** Note: Open the castLink in a webview tag **/
      /** needed useragent= "Mozilla/5.0 (SMART-TV; Linux; Tizen 2.4.0) AppleWebkit/538.1 (KHTML, like Gecko) SamsungBrowser/1.1 TV Safari/538.1" **/
      constructor of cast
      Cast(castConfig, callback, debug)
      castConfig {}
      • castName - Name of your device for reconize it in Cast apps
      • port - server port
      callback (notification, castlink)
      • CAST_START - return the url for start casting in a webview frame
      • CAST_STOP - return end of casting
      debug
      if you want debuging information, just set to true
      Functions
      • start() : start cast listener
      • stop() : force stop cast server
      Notes
      • Actually only YouTube works but may be other (in another update…)
