    MMM-RemoteCompliments does not appear
    18 Posts 5 Posters 3.6k Views 5 Watching
      sdetweil @justtrying
      @justtrying they introduced a bug in 2.11
      fix was to. put back the 2.10 version of the file.
      2.12 supposedly fixes it correctly. 2.12 has other problems
        justtrying @sdetweil
        @sdetweil as I said, I followed the instructions, I changed the socketclient.js file, still nothing.
        The MM is up to date as well.
        • N Offline
          Nero @justtrying
          @justtrying Did you ever get this to show up, I have just gone through the installation and nothing shows on my mirror not even the header. Thank you
          • T Offline
            tf2
            I would try starting over. I had a couple problems when I installed it, but I found every time the answers were actually in the instructions, just not quite how I would have expected to see them.
              sdetweil @tf2
              @tf2 u can also fork the repo, download it, edit the README.md file,add that change, push to your fork, and submit a pull request to the original repo to help others
              • T Offline
                tf2 @sdetweil
                @sdetweil I should have kept notes on what I didn’t do initially, but was in a hurry. I’ll be making a second mirror soon, and will do that.
                  sdetweil @tf2
                  @tf2 u don’t have to ‘install’ the repo to edit it.
                  just git clone your fork somewhere
                  • T Offline
                    tf2 @sdetweil
                    @sdetweil Sure. But if I don’t recall what problems I ran into and how I solved them, I won’t k ow what to modify in the documentation until I try following the instructions again.
