    Positions not working
    22 Posts 6 Posters 4.3k Views 5 Watching
      Joshsamuel
      Hi all,
      I am in the middle of my MagicMirror project and it’s been great. Kudos to all the people who have helped develop this for free.
      For some reason the middle_center and upper/lower_third positions aren’t working. When I set a specific module there, it aligns on the left side yet the vertical position is unaffected. How can I fix this?
      N.B. As far as I can remember, the original compliments module (which is now turned off) was correctly displayed in the lower_third
        JohnBachini @Joshsamuel
        @Joshsamuel post your config minus any api keys/user/pass and someone may spot the problem
          Joshsamuel
          I’m trying to get the MMM-ATM to display lower_third
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	//address: "localhost", // Address to listen on, can be:
                  address: "0.0.0.0",
          electronOptions: {
              webPreferences: {
                webviewTag: true
          	port: 8080,
          	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses
          	ipWhitelist: [],                                        // or add a specific IPv4 of 192.168.1.5 :
          	language: "en",
          	timeFormat: 12,
          	units: "metric",
          			     // false, default for all  NON-armv6l devices
          			module: "alert",
              		module: 'MMM-ATM',
              		position: 'lower_third',              // Works well anywhere
          			multipleChoice: "Yes",        // No = just the ? then the answer
          			useHeader: true,              // true if you want a header
          			header: "Not another trivia module!",   // Any text you want
          			maxWidth: "250px",             // Stretch or constrain according to region
            module: "MMM-GoogleAssistant",
            position: "fullscreen_above",
              debug: false,
              assistantConfig: {
                lang: "en-GB",
                projectId: "", // Required to use gaction.
                modelId: "", // (OPTIONAL for gaction)
                instanceId: "", // (OPTIONAL for gaction)
                latitude: ,
                longitude: ,
              responseConfig: {
                useScreenOutput: true,
                screenOutputCSS: "screen_output.css",
                screenOutputTimer: 5000,
                activateDelay: 250,
                useAudioOutput: true,
                useChime: true,
                newChime: true
              micConfig: { // put there configuration generated by auto-installer
                recorder: "arecord",
                device: "plughw:2",
              customActionConfig: {
                autoMakeAction: false,
                autoUpdateAction: false, // in RPI, gaction CLI might have some trouble.(current version should be 2.2.4, but for linux-arm, Google haven't updated) so leave this as false in RPI. I don't know it is solved or not.
                actionLocale: "en-GB", // At this moment, multi-languages are not supported, sorry. Someday I'll work.
              snowboy: {
                audioGain: 2.0,
                Frontend: true,
                Model: "jarvis",
                Sensitivity: null
              A2DServer: {
                useA2D: true,
                stopCommand: "thank you"
              recipes: [ "with-MMM-Spotify.js", "Reboot-Restart-Shutdown.js" ],
            module: "MMM-Assistant2Display",
              debug:false,
              useYoutube: true,
              links: {
                useLinks: true,
                displayDelay: 60 * 1000,
                scrollStep: 25,
                scrollInterval: 1000,
                scrollStart: 5000,
                scrollActivate: false,
                verbose: false
              photos: {
                usePhotos: true,
                displayDelay: 10 * 1000
              volume: {
                useVolume: true,
                volumePreset: "ALSA",
                myScript: null
              briefToday: {
                useBriefToday: false,
                welcome: "Hi"
              screen: {
                useScreen: false,
                delay: 5 * 60 * 1000,
                turnOffDisplay: true,
                ecoMode: true,
                displayCounter: true,
                displayBar: false,
                displayStyle: "Text",
                text: "Auto Turn Off Screen:",
                detectorSleeping: false,
                governorSleeping: false,
                rpi4: false
              pir: {
                usePir: false,
                gpio: 21,
                reverseValue: false
              governor: {
                useGovernor: false,
                sleeping: "powersave",
                working: "ondemand"
              internet: {
                useInternet: false,
                displayPing: false,
                delay: 2* 60 * 1000,
                scan: "google.fr",
                command: "pm2 restart 0",
                showAlert: true
              TelegramBot: {
                useTelecastSound: false,
                TelecastSound: "TelegramBot.ogg"
              cast: {
                useCast: false,
                castName: "MagicMirror_A2D",
                port: 8569
              spotify: {
                useSpotify: true,
                connectTo: "Raspotify",
                playDelay: 3000,
                minVolume: 10,
                maxVolume: 100
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			header: "My Calendar",
                                           maximumEntries: 5,
          						symbol: "calendar-check-o ",
          						url: "webcal://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"
          			                {	symbol: "MyCalendar",
                                                          url: ""
          			module: "currentweather",
          				locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				appid: ""
          			module: "weatherforecast",
          			header: "Weather Forecast",
          				appid: ""
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "The Guardian",
          						url: "http://theguardian.com/uk/rss"
          				showSourceTitle: true,
          				showPublishDate: true,
          				broadcastNewsFeeds: true,
          				broadcastNewsUpdates: true
           				 module: "MMM-Spotify",
           				 position: "top_left", // "bottom_bar" or "top_bar" for miniBar
             					 debug: false, // debug mode
             				 	style: "mini", // "default" or "mini" available (inactive for miniBar)
             				 	control: "default",
             				 	accountDefault: 0, // default account number, attention : 0 is the first account
             					 updateInterval: 1000, // update interval when playing
             					 idleInterval: 30000, // update interval on idle
             					 onStart: null, // disable onStart feature with `null`
             					 deviceDisplay: "Listening on", // text to display in the device block (default style only)
             					 allowDevices: [], //If you want to limit devices to display info, use this.
             					 // allowDevices: ["RASPOTIFY", "My iPhoneX", "My Home speaker"],
             					 miniBarConfig: {
             					   album: true, // display Album name in miniBar style
               					 scroll: true, // scroll title / artist / album in miniBar style
               					 logo: true, // display Spotify logo in miniBar style
                                 module: "MMM-GoogleFit",
                                            startOnMonday: "boolean",
                                            lastSevenDays: "boolean",
                                 module: 'MMM-GoogleTasks',
                                 header: "Google Tasks",
                          		listID: "",
          		module: 'MMM-PushBulletNotifications',
          		header: 'Notifications',
          		position: 'top_left',	// This can be any of the regions.
          			accessToken: "", //PushBullet API Access Token
          			endToEndPassword: null,
          			numberOfNotifications: 3,
          			filterTargetDeviceName: "",
          			showPushesSentToAllDevices: true,
          			onlyAllowCommandsFromSourceDevices: [],
          			fetchLimitPushBullet: 50,
          			showPushes: true,
          			showPushesOnLoad: true,
          			showDismissedPushes: true,
          			showMirroredNotifications: true,
          			onlyShowLastNotificationFromApplication: false,
          			showIndividualNotifications: false,
          			showSMS: true,
          			showMessage: true,
          			showIcons: true,
          			showDateTime: true,
          			localesDateTime: 'nl-NL',
          			playSoundOnNotificationReceived: true,
          			soundFile: 'modules/MMM-PushBulletNotifications/sounds/new-message.mp3',
          			maxMsgCharacters: 50,
          			maxHeaderCharacters: 32,
          			showModuleIfNoNotifications: true,
          			noNotificationsMessage: "No new notifications",
          			debugMode: false,
                          module: "MMM-Wallpaper",
                          position: "fullscreen_below",
                          	config: { // See "Configuration options" for more information.
                                  source: "bing",
                            	slideInterval: 60 * 1000 // Change slides every minute
          		//module: "MMM-MagicMover",
          		//position: "left",
          		//config: {
          		//	updateInterval: 60 * 1000,
          		//	maxMove: 20,
              	module: 'MMM-Remote-Control',
              	// uncomment the following line to show the URL of the remote control on the mirror
              	// , position: 'bottom_left'
              	// you can hide this module afterwards from the remote control itself
                 	 	customCommand: {},  // Optional, See "Using Custom Commands" below
                  	customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                  	showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                  	apiKey: "",         // Optional, See API/README.md for details
              	module: 'MMM-WiFiPassword',
               	   //See 'Configuration options' for more information.
                	  network: "",
                 	  password: "",
            sdetweil @Joshsamuel
            @Joshsamuel lower_third is not one of the positions… see ~/MagicMirror/index.html for the defined positions
            can’t paste it here
              Joshsamuel
              @sdetweil Is there a reason why my index.html when opened is a black screen?
              • ? Offline
                A Former User @sdetweil
                This post is deleted!
                • ? Offline
                  A Former User @Joshsamuel
                    Joshsamuel @Guest
                    @hango No clue what I’m looking for here but this is what I can see Errors 1 Errors 2
                    • ? Offline
                      A Former User
                        Joshsamuel @Guest
                        @hango The path is MagicMirror, the ‘r’ is at the start of the next line
                          sdetweil @Guest
                          @hango yep, sorry, missed it…
                          you don’t open index.html with a browser… its the shell that MM uses to place module output
                            @Joshsamuel error file not found, looks like you didn’t follow some install instructions,
                            there was a step
                            npm install
                            looks like something happened to the node_modules folder where the libraries are saved
                            • ? Offline
                              A Former User
                                Joshsamuel @sdetweil
                                @sdetweil I ran npm install in the MM directory, it then said new patch version of npm available (6.14.4 > 6.14.5). I then tried to install this using
                                npm install -g npm
                                Then got the following message with some errors:
                                pi@raspberrypi:~/MagicMirror $ npm install -g npm
                                npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/graceful-fs
                                npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mkdirp
                                npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/nopt
                                npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-registry-fetch
                                npm ERR! code EACCES
                                npm ERR! syscall access
                                npm ERR! path /usr/lib/node_modules/npm/node_modules/graceful-fs
                                npm ERR! errno -13
                                npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/graceful-fs'
                                npm ERR!  { [Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/graceful-fs']
                                npm ERR!   stack:
                                npm ERR!    'Error: EACCES: permission denied, access \'/usr/lib/node_modules/npm/node_modules/graceful-fs\'',
                                npm ERR!   errno: -13,
                                npm ERR!   code: 'EACCES',
                                npm ERR!   syscall: 'access',
                                npm ERR!   path: '/usr/lib/node_modules/npm/node_modules/graceful-fs' }
                                npm ERR!
                                npm ERR! The operation was rejected by your operating system.
                                npm ERR! It is likely you do not have the permissions to access this file as the current user
                                npm ERR!
                                npm ERR! If you believe this might be a permissions issue, please double-check the
                                npm ERR! permissions of the file and its containing directories, or try running
                                npm ERR! the command again as root/Administrator.
                                npm ERR!     /home/pi/.npm/_logs/2020-06-22T17_34_29_233Z-debug.log
                                S lavolp3L 2 Replies Last reply Reply Quote 0
                                  @Joshsamuel yeh, don’t do that…
                                  to recover do
                                  cd ~/MagicMirror
                                  npm install
                                    @sdetweil Just did that, still haven’t got position working
                                      @Joshsamuel did u examine the error in index.html as suggested>
                                      what does the log look like, both the console log (or pm2 logs --lines=100)
                                      and the developer window console?
                                      you have broken code, so nothing will be working right
                                      • lavolp3L Offline
                                        lavolp3 Module Developer @Joshsamuel
                                        @Joshsamuel
                                        npm ERR! Error: EACCES: permission denied, access ‘/usr/lib/node_modules/npm/node_modules/graceful-fs’
                                        npm ERR! { [Error: EACCES: permission denied, access ‘/usr/lib/node_modules/npm/node_modules/graceful-fs’]
                                        npm itself is often installed with sudo priviledge (like here, hence “permission denied”).
                                        Therefore you’d need to do sudo npm install -g npm
                                        How to troubleshoot modules
                                        MMM-soccer v2, MMM-AVStock
                                        • BKeyportB Offline
                                          BKeyport Module Developer
                                          By the way, the regions are:
                                          top_bar
                                          bottom_bar
                                          top_left
                                          bottom_left
                                          top_center
                                          bottom_center
                                          top_right
                                          bottom_right
                                          upper_third
                                          lower_third
                                          middle_center
                                          fullscreen_above
                                          fullscreen_below
                                            Joshsamuel @lavolp3
                                            @lavolp3 I ran the npm install in the MM directory and the update, no error messages this time, but position still doesn’t work
                                            pi@raspberrypi:~ $ cd ~/MagicMirror
                                            pi@raspberrypi:~/MagicMirror $ sudo npm install
                                            npm WARN lifecycle magicmirror@2.11.0~install: cannot run in wd magicmirror@2.11.0 echo "Installing vendor files ...
                                            npm WARN lifecycle " && cd vendor && npm install --loglevel=error (wd=/home/pi/MagicMirror)
                                            npm WARN lifecycle magicmirror@2.11.0~postinstall: cannot run in wd magicmirror@2.11.0 npm run install-fonts && echo "MagicMirror installation finished successfully!
                                            npm WARN lifecycle " (wd=/home/pi/MagicMirror)
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
                                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                            audited 1082 packages in 20.995s
                                            77 packages are looking for funding
                                              run `npm fund` for details
                                            found 3 low severity vulnerabilities
                                              run `npm audit fix` to fix them, or `npm audit` for details
                                            pi@raspberrypi:~/MagicMirror $ sudo npm install -g npm
                                            /usr/bin/npm -> /usr/lib/node_modules/npm/bin/npm-cli.js
                                            /usr/bin/npx -> /usr/lib/node_modules/npm/bin/npx-cli.js
                                            + npm@6.14.5
                                            updated 5 packages in 38.973s
