    Positions not working
    22 Posts 6 Posters 3.5k Views 5 Watching
      Joshsamuel
      I’m trying to get the MMM-ATM to display lower_third
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	//address: "localhost", // Address to listen on, can be:
              address: "0.0.0.0",
      electronOptions: {
          webPreferences: {
            webviewTag: true
      	port: 8080,
      	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses
      	ipWhitelist: [],                                        // or add a specific IPv4 of 192.168.1.5 :
      	language: "en",
      	timeFormat: 12,
      	units: "metric",
      			     // false, default for all  NON-armv6l devices
      			module: "alert",
          		module: 'MMM-ATM',
          		position: 'lower_third',              // Works well anywhere
      			multipleChoice: "Yes",        // No = just the ? then the answer
      			useHeader: true,              // true if you want a header
      			header: "Not another trivia module!",   // Any text you want
      			maxWidth: "250px",             // Stretch or constrain according to region
        module: "MMM-GoogleAssistant",
        position: "fullscreen_above",
          debug: false,
          assistantConfig: {
            lang: "en-GB",
            projectId: "", // Required to use gaction.
            modelId: "", // (OPTIONAL for gaction)
            instanceId: "", // (OPTIONAL for gaction)
            latitude: ,
            longitude: ,
          responseConfig: {
            useScreenOutput: true,
            screenOutputCSS: "screen_output.css",
            screenOutputTimer: 5000,
            activateDelay: 250,
            useAudioOutput: true,
            useChime: true,
            newChime: true
          micConfig: { // put there configuration generated by auto-installer
            recorder: "arecord",
            device: "plughw:2",
          customActionConfig: {
            autoMakeAction: false,
            autoUpdateAction: false, // in RPI, gaction CLI might have some trouble.(current version should be 2.2.4, but for linux-arm, Google haven't updated) so leave this as false in RPI. I don't know it is solved or not.
            actionLocale: "en-GB", // At this moment, multi-languages are not supported, sorry. Someday I'll work.
          snowboy: {
            audioGain: 2.0,
            Frontend: true,
            Model: "jarvis",
            Sensitivity: null
          A2DServer: {
            useA2D: true,
            stopCommand: "thank you"
          recipes: [ "with-MMM-Spotify.js", "Reboot-Restart-Shutdown.js" ],
        module: "MMM-Assistant2Display",
          debug:false,
          useYoutube: true,
          links: {
            useLinks: true,
            displayDelay: 60 * 1000,
            scrollStep: 25,
            scrollInterval: 1000,
            scrollStart: 5000,
            scrollActivate: false,
            verbose: false
          photos: {
            usePhotos: true,
            displayDelay: 10 * 1000
          volume: {
            useVolume: true,
            volumePreset: "ALSA",
            myScript: null
          briefToday: {
            useBriefToday: false,
            welcome: "Hi"
          screen: {
            useScreen: false,
            delay: 5 * 60 * 1000,
            turnOffDisplay: true,
            ecoMode: true,
            displayCounter: true,
            displayBar: false,
            displayStyle: "Text",
            text: "Auto Turn Off Screen:",
            detectorSleeping: false,
            governorSleeping: false,
            rpi4: false
          pir: {
            usePir: false,
            gpio: 21,
            reverseValue: false
          governor: {
            useGovernor: false,
            sleeping: "powersave",
            working: "ondemand"
          internet: {
            useInternet: false,
            displayPing: false,
            delay: 2* 60 * 1000,
            scan: "google.fr",
            command: "pm2 restart 0",
            showAlert: true
          TelegramBot: {
            useTelecastSound: false,
            TelecastSound: "TelegramBot.ogg"
          cast: {
            useCast: false,
            castName: "MagicMirror_A2D",
            port: 8569
          spotify: {
            useSpotify: true,
            connectTo: "Raspotify",
            playDelay: 3000,
            minVolume: 10,
            maxVolume: 100
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "My Calendar",
                                       maximumEntries: 5,
      						symbol: "calendar-check-o ",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"
      			                {	symbol: "MyCalendar",
                                                      url: ""
      			module: "currentweather",
      				locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: ""
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				appid: ""
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "The Guardian",
      						url: "http://theguardian.com/uk/rss"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
       				 module: "MMM-Spotify",
       				 position: "top_left", // "bottom_bar" or "top_bar" for miniBar
         					 debug: false, // debug mode
         				 	style: "mini", // "default" or "mini" available (inactive for miniBar)
         				 	control: "default",
         				 	accountDefault: 0, // default account number, attention : 0 is the first account
         					 updateInterval: 1000, // update interval when playing
         					 idleInterval: 30000, // update interval on idle
         					 onStart: null, // disable onStart feature with `null`
         					 deviceDisplay: "Listening on", // text to display in the device block (default style only)
         					 allowDevices: [], //If you want to limit devices to display info, use this.
         					 // allowDevices: ["RASPOTIFY", "My iPhoneX", "My Home speaker"],
         					 miniBarConfig: {
         					   album: true, // display Album name in miniBar style
           					 scroll: true, // scroll title / artist / album in miniBar style
           					 logo: true, // display Spotify logo in miniBar style
                             module: "MMM-GoogleFit",
                                        startOnMonday: "boolean",
                                        lastSevenDays: "boolean",
                             module: 'MMM-GoogleTasks',
                             header: "Google Tasks",
                      		listID: "",
      		module: 'MMM-PushBulletNotifications',
      		header: 'Notifications',
      		position: 'top_left',	// This can be any of the regions.
      			accessToken: "", //PushBullet API Access Token
      			endToEndPassword: null,
      			numberOfNotifications: 3,
      			filterTargetDeviceName: "",
      			showPushesSentToAllDevices: true,
      			onlyAllowCommandsFromSourceDevices: [],
      			fetchLimitPushBullet: 50,
      			showPushes: true,
      			showPushesOnLoad: true,
      			showDismissedPushes: true,
      			showMirroredNotifications: true,
      			onlyShowLastNotificationFromApplication: false,
      			showIndividualNotifications: false,
      			showSMS: true,
      			showMessage: true,
      			showIcons: true,
      			showDateTime: true,
      			localesDateTime: 'nl-NL',
      			playSoundOnNotificationReceived: true,
      			soundFile: 'modules/MMM-PushBulletNotifications/sounds/new-message.mp3',
      			maxMsgCharacters: 50,
      			maxHeaderCharacters: 32,
      			showModuleIfNoNotifications: true,
      			noNotificationsMessage: "No new notifications",
      			debugMode: false,
                      module: "MMM-Wallpaper",
                      position: "fullscreen_below",
                      	config: { // See "Configuration options" for more information.
                              source: "bing",
                        	slideInterval: 60 * 1000 // Change slides every minute
      		//module: "MMM-MagicMover",
      		//position: "left",
      		//config: {
      		//	updateInterval: 60 * 1000,
      		//	maxMove: 20,
          	module: 'MMM-Remote-Control',
          	// , position: 'bottom_left'
             	 	customCommand: {},  // Optional, See "Using Custom Commands" below
              	customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
              	showModuleApiMenu: true, // Optional, Enable the Module Controls menu
              	apiKey: "",         // Optional, See API/README.md for details
          	module: 'MMM-WiFiPassword',
           	   //See 'Configuration options' for more information.
            	  network: "",
             	  password: "",
        sdetweil @Joshsamuel
        @Joshsamuel lower_third is not one of the positions… see ~/MagicMirror/index.html for the defined positions
        can’t paste it here
          Joshsamuel
          @sdetweil Is there a reason why my index.html when opened is a black screen?
            A Former User @sdetweil
              A Former User @Joshsamuel
                Joshsamuel @Guest
                @hango No clue what I’m looking for here but this is what I can see Errors 1 Errors 2
                  A Former User
                    Joshsamuel @Guest
                    @hango The path is MagicMirror, the ‘r’ is at the start of the next line
                      sdetweil @Guest
                      @hango yep, sorry, missed it…
                      you don’t open index.html with a browser… its the shell that MM uses to place module output
                        @Joshsamuel error file not found, looks like you didn’t follow some install instructions,
                        there was a step
                        npm install
                        looks like something happened to the node_modules folder where the libraries are saved
