    Positions not working
    22 Posts 6 Posters 4.2k Views 5 Watching
      A Former User @Joshsamuel
        Joshsamuel @Guest
        @hango No clue what I’m looking for here but this is what I can see Errors 1 Errors 2
          A Former User
            Joshsamuel @Guest
            @hango The path is MagicMirror, the ‘r’ is at the start of the next line
              sdetweil @Guest
              @hango yep, sorry, missed it…
              you don’t open index.html with a browser… its the shell that MM uses to place module output
                sdetweil @Joshsamuel
                @Joshsamuel error file not found, looks like you didn’t follow some install instructions,
                there was a step
                npm install
                looks like something happened to the node_modules folder where the libraries are saved
                  A Former User
                    Joshsamuel @sdetweil
                    @sdetweil I ran npm install in the MM directory, it then said new patch version of npm available (6.14.4 > 6.14.5). I then tried to install this using
                    npm install -g npm
                    Then got the following message with some errors:
                    pi@raspberrypi:~/MagicMirror $ npm install -g npm
                    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/graceful-fs
                    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mkdirp
                    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/nopt
                    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-registry-fetch
                    npm ERR! code EACCES
                    npm ERR! syscall access
                    npm ERR! path /usr/lib/node_modules/npm/node_modules/graceful-fs
                    npm ERR! errno -13
                    npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/graceful-fs'
                    npm ERR!  { [Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/graceful-fs']
                    npm ERR!   stack:
                    npm ERR!    'Error: EACCES: permission denied, access \'/usr/lib/node_modules/npm/node_modules/graceful-fs\'',
                    npm ERR!   errno: -13,
                    npm ERR!   code: 'EACCES',
                    npm ERR!   syscall: 'access',
                    npm ERR!   path: '/usr/lib/node_modules/npm/node_modules/graceful-fs' }
                    npm ERR!
                    npm ERR! The operation was rejected by your operating system.
                    npm ERR! It is likely you do not have the permissions to access this file as the current user
                    npm ERR!
                    npm ERR! If you believe this might be a permissions issue, please double-check the
                    npm ERR! permissions of the file and its containing directories, or try running
                    npm ERR! the command again as root/Administrator.
                    npm ERR!     /home/pi/.npm/_logs/2020-06-22T17_34_29_233Z-debug.log
                    S lavolp3L 2 Replies Last reply Reply Quote 0
                      @Joshsamuel yeh, don’t do that…
                      to recover do
                      npm install
                        @sdetweil Just did that, still haven’t got position working
                          @Joshsamuel did u examine the error in index.html as suggested>
                          what does the log look like, both the console log (or pm2 logs --lines=100)
                          and the developer window console?
                          you have broken code, so nothing will be working right
                          • lavolp3L Offline
                            lavolp3 Module Developer @Joshsamuel
                            @Joshsamuel
                            npm ERR! Error: EACCES: permission denied, access ‘/usr/lib/node_modules/npm/node_modules/graceful-fs’
                            npm ERR! { [Error: EACCES: permission denied, access ‘/usr/lib/node_modules/npm/node_modules/graceful-fs’]
                            npm itself is often installed with sudo priviledge (like here, hence “permission denied”).
                            Therefore you’d need to do sudo npm install -g npm
                            How to troubleshoot modules
                            MMM-soccer v2, MMM-AVStock
                            • BKeyportB Offline
                              BKeyport Module Developer
                              By the way, the regions are:
                              top_bar
                              bottom_bar
                              top_left
                              bottom_left
                              top_center
                              bottom_center
                              top_right
                              bottom_right
                              upper_third
                              lower_third
                              middle_center
                              fullscreen_above
                              fullscreen_below
                                Joshsamuel @lavolp3
                                @lavolp3 I ran the npm install in the MM directory and the update, no error messages this time, but position still doesn’t work
                                pi@raspberrypi:~/MagicMirror $ sudo npm install
                                npm WARN lifecycle magicmirror@2.11.0~install: cannot run in wd magicmirror@2.11.0 echo "Installing vendor files ...
                                npm WARN lifecycle " && cd vendor && npm install --loglevel=error (wd=/home/pi/MagicMirror)
                                npm WARN lifecycle magicmirror@2.11.0~postinstall: cannot run in wd magicmirror@2.11.0 npm run install-fonts && echo "MagicMirror installation finished successfully!
                                npm WARN lifecycle " (wd=/home/pi/MagicMirror)
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                audited 1082 packages in 20.995s
                                77 packages are looking for funding
                                  run `npm fund` for details
                                found 3 low severity vulnerabilities
                                  run `npm audit fix` to fix them, or `npm audit` for details
                                pi@raspberrypi:~/MagicMirror $ sudo npm install -g npm
                                /usr/bin/npm -> /usr/lib/node_modules/npm/bin/npm-cli.js
                                /usr/bin/npx -> /usr/lib/node_modules/npm/bin/npx-cli.js
                                + npm@6.14.5
                                updated 5 packages in 38.973s
                                  Joshsamuel
                                  Hi all, just realised that the positions are working for me but the specific module (MMM-ATM which supposedly works well anywhere) has issues when placed in the middle.
                                  Moving the news bar and other modules to lower_third or middle_center works fine, definitely should’ve tested this from the beginning.
                                  Thanks for all the help from everyone!
                                  • BKeyportB Offline
                                    BKeyport Module Developer @Joshsamuel
                                    @Joshsamuel glad you got it fixed.
