    MMM-ImageSlideshow not showing up.
    1 Posts 1 Posters 310 Views 1 Watching
    • J
      joeylockie
      I have been trying to get MMM-ImageSlideshow to show up, this is my code:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "fr",
      	timeFormat: 24,
      	units: "metric",
      			     // false, default for all  NON-armv6l devices
      			module: "alert",
      			//module: "updatenotification",
      			//position: "top_bar"
              module: 'MMM-ModuleScheduler',
                  global_schedule: [
                                   {from: '0 6 * * *', to: '10 17 * * *', groupClass: 'daytime_scheduler'},
                                   {from: '37 17 * * *', to: '59 5 * * *', groupClass: 'nighttime_scheduler'},
      			module: "clock",
      			position: "top_left"
      			//module: "compliments",
      			//position: "lower_third"
      			module: "currentweather",
      				locationID: "6138121", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "############",
      				roundTemp: true
      			module: "weatherforecast",
      			position: "top _left",
      			header: "Weather Forecast",
      				fade: false,
      				roundTemp: true
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "Journalde Montreal",
      						url: "https://www.journaldemontreal.com/rss.xml"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
      	module: 'MMM-Globe',
      	position: 'middle_center',
      	classes: 'daytime_scheduler',
      		style: 'geoColor',
      		imageSize: 475,
      		ownImagePath:'',
      		updateInterval: 10*60*1000
      		module: 'MMM-ImageSlideshow',
      	position: "middle_center",
      	classes: 'nighttime_scheduler',
      			imagePaths: ['modules/MMM-ImageSlideshow/Images'],
                      slideshowSpeed: 100,
                      fixedImageWidth: 500,
                      fixedImageHeight: 500,
                      randomizeImageOrder: true,
      		module: 'MMM-Todoist',
      		position: 'top_right',	// This can be any of the regions. Best results in left or right regions.
      		header: 'Todo List', // This is optional
      		config: { // See 'Configuration options' for more information.
      			accessToken: '############',
      			maximumEntries: 25,
      			updateInterval: 5*60*1000, // Update every 10 minutes
      			fade: false,
      			// projects and/or labels is mandatory:
      			projects: [ 2230379200,
      						2229190923,
      						2229190958,
      						2229191069,
      						2229194307,
      			labels: [  ], // Tasks for any projects with these labels will be shown.
      			sortType: "dueDateAsc",
      			displayTasksWithinDays: 40,
      I tryed removing the ModuleScheduler and the global module and all that but still no image? what am I doing wrong the image folder is modules/MMM-ImageSlideshow/Images
