    Screencast not showing up on phone
    2 Posts 2 Posters 690 Views 2 Watching
    • A
      Alex_Corroon
      I’m very new to the raspberry pi and MagicMirror stuff so please excuse my ignorance. I downloaded the screencast module and its in my module folder. I also added the script to the config/config.js. However when I run my magic mirror there is no option for me to cast to the mirror when I go into youtube. I feel like I might have made a mistake with the configeration part i added to the modules array but it seems to be correct. If anyone could give me some pointers that would be great.
      Thanks!
      • M
        majik655
        I can’t remember if turning on OpenGL driver was my issue or not with this…
        As long as your config files is correct (it isnt a hard config file I will post mine below)…
        Try opening a terminal window and type sudo raspi-config
        go to “Advanced Options” and then “OpenGL Driver”
        Depending on the hardware you have or what PI model you are using you may have just one option or a couple…
        IF you have multiple options like I have seen … one was FAKE KMS and the other was FULL KMS…
        I had to choose FULL KMS (i think for raspberry pi3)… on my raspberry pi 4 I believe there is only one option…choose it.
        (might want to reboot)… cant remember if needed or makes you.
        Then try again … make sure your device is on the same wifi network as your mirror …
        You should see your mirror name …
        I can’t think of what more there could be … unless your router is blocking the default port?
        You did do npm install in the module directory after cloning it right?
        My config for the module…
        			module: 'MMM-Screencast',
        			position: 'center', // This position is for a hidden <div /> and not the screencast window
        				position: 'center',
        				height: 300,
        				width: 500,
