    Weather Forecast only showing 1 day
    3 Posts 2 Posters 549 Views 2 Watching
    • T Offline
      tasanford11
      I am hoping the answer isn’t right in front of me, as I have been looking through my config files for what seems like forever.
      When I first installed MM, I got my API key and set everything up, and the currentWeather and weatherForecast modules worked just as expected. I recently updated to get rid of the pesky update notification, and now my weather forecast module only shows one day. I have not changed anything in my config.js or my weatherforecast.js files.
      config.js:
      module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "5160315",
      				appid: "xxxx"
      weatherforecast.js: unchanged from repo: https://github.com/MichMich/MagicMirror/blob/master/modules/default/weatherforecast/weatherforecast.js
      Someone help me please so I don’t lose my mind! I just finished the entire build and this little hiccup is driving me crazy!
      Also, sorry if there is a post for this already, I tried looking for something but did not find anything that seemed to match up.
      • T Offline
        tasanford11 @tasanford11
        Just a quick update, I confirmed that the weather forecast shows up as expected when running version 2.11.0, so I am not sure what change was made in the update that could cause this.
        **Also, The image attached shows two days of forecasted weather. It fluctuates between 1 and 2 days without any changes, I’m assuming whatever the root cause for the bigger issue is also the cause for this unexpected behavior.
          sdetweil @tasanford11
          @tasanford11 there was a bug introduced in 2.12,
          a fix is available in the develop branch
          how did u install? scripted or manual
          if manual do
          cd ~/MagicMirror
          git checkout develop
          then restart MagicMirror
          if my scripted install do
          cd~/MagicMirror
          git fetch origin develop:develop
          the restart MagicMirror
