    MMM-Face-Reco-DNN Problem
    3 Posts 2 Posters 694 Views 2 Watching
    • ParvezP Offline
      Parvez
      MMM-Face-Reco-DNN dose not work
      When i stop npm magic mirror show thats code :
      [2020-07-24 22:24:05.148] [LOG] [MMM-Face-Reco-DNN] Terminate python
      events.js:177
      throw er; // Unhandled ‘error’ event
      Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      at doWrite (_stream_writable.js:413:19)
      at writeOrBuffer (_stream_writable.js:401:5)
      at WriteStream.Writable.write (_stream_writable.js:301:11)
      at Object.con. [as error] (/home/pi/MagicMirror/node_modules/console-stamp/main.js:148:46)
      at process. (/home/pi/MagicMirror/js/app.js:37:6)
      at process.emit (events.js:205:15)
      at processEmit [as emit] (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/signal-exit/index.js:155:32)
      at process._fatalException (internal/process/execution.js:146:25)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 7
      npm ERR! magicmirror@2.12.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dav"
      npm ERR! Exit status 7
      npm ERR!
      npm ERR! Failed at the magicmirror@2.12.0 start script.
      npm ERR! /home/pi/.npm/_logs/2020-07-24T16_24_05_354Z-debug.log
      Parvez Ahmed
        sdetweil @Parvez
        @Parvez
        could u explain that? there is no npm stop command.
        there is for pm2, but not npm
        there error here is because of python
        ParvezP 1 Reply Last reply Reply Quote 0
        • ParvezP Offline
          Parvez @sdetweil
          @sdetweil i start magic mirror : ~/MagicMirror $ npm start
          and stop mirror Ctrl+q then show that error code .
          -my english is not good
          Parvez Ahmed
