    [MMM-NewsFeedTicker] scroll from left to right only?
    41 Posts 3 Posters 17.0k Views 4 Watching
    • Cr4z33C
      Cr4z33
      Can someone please tell me what to edit to have the news scrolling from left to right only (and not also from right to left)?
      @-webkit-keyframes marquee {
        0% { left: 100%; }
        100% { left: -100%; }
      @-moz-keyframes marquee {
        0% { left: 100%; }
      @-ms-keyframes marquee {
        0% { left: 100%; }
      @-o-keyframes marquee {
        0% { left: 100%; }
      @keyframes marquee {
        0% { left: 100%; }
      .MMM-NewsFeedTicker {
        width: 100%;
        height: 50px;
        line-height: 100%;
        overflow: hidden;
        background: rgb(104, 9, 9); /* background color - change to 'none' if don't want */
      .MMM-NewsFeedTicker .tickerbody {
        margin: 0 auto;
        width: 100%;
        padding-top: 5px;
        position: relative;
        white-space: nowrap;
        overflow: visible;
        -webkit-animation: marquee linear infinite;
        -moz-animation: marquee linear infinite;
        -ms-animation: marquee linear infinite;
        -o-animation: marquee linear infinite;
      .MMM-NewsFeedTicker .headline {
        font-size: 40px;
        font-weight: bold;
      .MMM-NewsFeedTicker .image {
        position: absolute;
        display: inline-block;
        vertical-align: middle;
        bottom: 0;
        left: 0;
        height: 50px;
        z-index: 100;
        background: rgb(255, 255, 255); /* white background for image */
        sdetweil @Cr4z33
        @Cr4z33 see
        https://www.quackit.com/css/codes/marquees/
        • Cr4z33C
          Cr4z33 @sdetweil
          @sdetweil thanks I already saw that page, but it talks about translateX and there’s no evidence of it in that module’s CSS.
            sdetweil @Cr4z33
            @Cr4z33 ok, so. try it. maybe the default is right to left if not specified.
            worst case u have the existing file still
            • Cr4z33C
              Cr4z33 @sdetweil
              @sdetweil nope I didn’t get what I wanted. :person_shrugging_medium-dark_skin_tone:
                A Former User
                @Cr4z33 : see this
                I think it can help
                  sdetweil
                  i did this, commented out the old in the MMM-NewsFeedTicker.css
                  and replaced with this
                  /*@-webkit-keyframes marquee {
                    0% { left: 100%; }
                    0% { left: 100%; }
                    0% { left: 100%; }
                    0% { left: 100%; }
                    0% { left: 100%; }
                  /* new stuff here */
                     0% {
                      transform: translate(-100%, 0);
                    50% {
                      transform: translate(-50%, 0);
                    100% {
                      transform: translate(0, 0);
                  • Cr4z33C
                    Cr4z33 @sdetweil
                    @sdetweil thank you gonna try asap! :D
                    • Cr4z33C
                      Cr4z33
                      OK this is getting weird now because I applied the above code and it STILL keeps scrolling back and forth! :anguished_face:
                        sdetweil @Cr4z33
                        @Cr4z33 did u delete the old code?
                          0% { left: 100%; }
                          0% { left: 100%; }
                          0% { left: 100%; }
                          0% { left: 100%; }
                          0% { left: 100%; }
                        notice the /* and */
                        • Cr4z33C
                          Cr4z33
                          @sdetweil of course I did. :)
                            sdetweil @Cr4z33
                            @Cr4z33 whoops. left out a change comment out the animations for other browsers
                              margin: 0 auto;
                              width: 100%;
                              padding-top: 5px;
                              position: relative;
                              overflow: visible;
                              /*-webkit-animation: marquee linear infinite;
                              -o-animation: marquee linear infinite; */
                            weird… on 2.11 it scrolls right to left
                            on 2.12 is scrolls left to right
                              sdetweil
                              i installed it again on my desktop system (from laptop), and it works as expected (on MM 2.12)
                              • Cr4z33C
                                Cr4z33 @sdetweil
                                @sdetweil nope mine ist still going back and forth.
                                  sdetweil @Cr4z33
                                  @Cr4z33 weird… I just re-installed MM and the module and changed the css and changed the newsfeed module config entry to MMM-NewsFeedTicker and started, left to right
                                  			module: "MMM-NewsFeedTicker",
                                  			position: "bottom_bar",
                                  				feeds: [
                                  						title: "New York Times",
                                  						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                                  				showSourceTitle: true,
                                  				showPublishDate: true,
                                  				broadcastNewsFeeds: true,
                                  				broadcastNewsUpdates: true
                                    sdetweil
                                    from my dropbox , screen video capture
                                    https://www.dropbox.com/s/vab6t9j0oa95zyw/Kazam_screencast_00000.mp4?dl=0
                                    Cr4z33C 2 Replies Last reply Reply Quote 0
                                    • Cr4z33C
                                      Cr4z33 @sdetweil
                                      This post is deleted!
                                      • Cr4z33C
                                        Cr4z33 @sdetweil
                                          sdetweil
                                          I don’t understand. the default, the text ( the beginning of the line of text) starts to appear on the right side of the screen and scrolls to the left ( last showing the end of the line of text)
                                          my change, per your request, the end of the text appears on the left of the screen, and scrolls to the right ( last showing the beginning of the line of text)
                                          this is for left to right language English. I don’t know if language setting changes the default marquee order
                                            @Cr4z33 did u see my post above?
                                            • 1 / 3
