    [MMM-NewsFeedTicker] scroll from left to right only?
    41 Posts 3 Posters 17.4k Views 4 Watching
    • Cr4z33C
      Cr4z33 @sdetweil
      @sdetweil said in [MMM-NewsFeedTicker] scroll from left to right only?:
      @Cr4z33 did u see my post above?
      Yep saw also the video.
      Dunno why my MM system ignores the CSS edit… :confounded_face:
        sdetweil @Cr4z33
        @Cr4z33 do you have a custom.css setting which would override the module?
        Cr4z33C 1 Reply Last reply
        • Cr4z33C
          Cr4z33 @sdetweil
          @sdetweil indeed so that’s the reason then?? :anguished_face:
          Update:
          Nope it keeps going back and forth even without custom.css entry…
            sdetweil @Cr4z33
            @Cr4z33 did u delete custom.css, comment out or what?
            and restarted MM
            • Cr4z33C
              Cr4z33 @sdetweil
              @sdetweil I deleted the file.
              Yes I restarted MM.
                sdetweil @Cr4z33
                @Cr4z33 that is
                ~/MagicMirror/css/custom.css
                right?
                and u edited the MMM-NewsFeedTicker.css in the MMM-NewsFeedTicker module folder to add my changes, yes?
                • Cr4z33C
                  Cr4z33 @sdetweil
                  @Cr4z33 that is
                  right?
                  Correct. 👍🏽
                    sdetweil @Cr4z33
                    @Cr4z33 the module is still requesting to load the css directly, right? with the right name
                        getStyles: function() {
                            return ["MMM-NewsFeedTicker.css"];
                    one more thing, my module is running all default values, cause i changed the name of the default newsfeed module to this one… but did NOT set any config values…
                    			module: "MMM-NewsFeedTicker",
                    			position: "bottom_bar",
                    				feeds: [
                    						title: "New York Times",
                    				showSourceTitle: true,
                    				showPublishDate: true,
                    				broadcastNewsFeeds: true,
                    				broadcastNewsUpdates: true
                    • Cr4z33C
                      Cr4z33 @sdetweil
                      @sdetweil I tried using your defaults as well by getting the issue again.
                      At this point could Debian 10 running (natively of course) on an Intel NUC be the problem?
                        sdetweil @Cr4z33
                        @Cr4z33 I’m doing this on Intel.
                        rename your MMM-NewsFeedTicker folder out of the way and clone my fork
                        https://github.com/sdetweil/MMM-NewsFeedTicker
                        Reply Quote 1
                        • Cr4z33C
                          Cr4z33 @sdetweil
                          @sdetweil cheers going to do it as soon as I am done with reinstalling Debian (stupid issue with USB mics not detected anymore…)! 👍🏽
                          I will reply here.
                          • Cr4z33C
                            Cr4z33
                            @sdetweil I’ve installed your fork and… it’s going back and forth too! :smiling_face_with_open_mouth_cold_sweat:
                            Here’s my module config just in case:
                            			disabled: false,
                            			//classes: "day_scheduler",
                            					feeds: [
                            							title: "Cambio Euro/Dollaro",
                            							url: "https://eur.fxexchangerate.com/usd.xml",
                            							customLogo: "xe.png"
                            							title: "Agenzia ANSA - Ultima Ora",
                            							url: "https://www.ansa.it/sito/notizie/topnews/topnews_rss.xml",
                            							customLogo: "ansa.jpg"
                            							title: "La Gazzetta del Mezzogiorno - Lecce",
                            							url: "https://www.lagazzettadelmezzogiorno.it/rss.jsp?sezione=113",
                            							customLogo: "gdm.jpg"
                            							title: "Hardware Upgrade",
                            							url: "https://feeds.hwupgrade.it/rss_hwup.xml",
                            							customLogo: "hwu.png"
                            							title: "HDblog.it",
                            							url: "http://feeds.feedburner.com/hd-blog?format=xml",
                            							customLogo: "hdblog.png"
                            							title: "Tom's Hardware",
                            							url: "https://www.tomshw.it/feed/",
                            							customLogo: "tomshw.png"
                            							title: "Punto Informatico",
                            							url: "https://www.punto-informatico.it/feed/",
                            							customLogo: "pi.png"
                            							title: "LeccePrima",
                            							url: "http://www.lecceprima.it/rss/",
                            							customLogo: "lecceprima.png"
                            							title: "Galatina.it",
                            							url: "http://www.galatina.it/rss.xml",
                            							customLogo: "galatina.png"
                              sdetweil @Cr4z33
                              @Cr4z33 so, u have some custom class somewhere.
                              • Cr4z33C
                                Cr4z33 @sdetweil
                                @sdetweil OK where should I look at please ? 😅
                                  sdetweil @Cr4z33
                                  @Cr4z33 no… idea… I would reinstall MM (use my script), just rename the old MM folder to something else,
                                  then install my module version to verify
                                  then u can start looking around… i installed from scratch like that to test before I sent to you, and others have confirmed it works for them too.
                                  Cr4z33C ? 2 Replies Last reply
                                  • Cr4z33C
                                    Cr4z33 @sdetweil
                                    @sdetweil okie dokie I am going to reinstall both Debian and MM too in the next days because of other issues.
                                    I will reply here thanks.
                                    ? 1 Reply Last reply
                                      A Former User @sdetweil
                                      Confirmed works with Debian dev desktop
                                        A Former User @Cr4z33
                                        @Cr4z33 said in [MMM-NewsFeedTicker] scroll from left to right only?:
                                        I don’t understand why reinstall all ecosystem. but it’s your choice ;)
                                          sdetweil @Guest
                                          @Bugsounet he said “because of other issues.”
                                            A Former User
                                            fortunately I don’t reinstall debian with each problem … otherwise I will not get out!
                                            Usually the problem comes from the MM directory, I think
                                            because with debian some permission missing
                                            • 2 / 3
