    [MMM-NewsFeedTicker] scroll from left to right only?
    41 Posts 3 Posters 16.9k Views 4 Watching
      from my dropbox , screen video capture
      https://www.dropbox.com/s/vab6t9j0oa95zyw/Kazam_screencast_00000.mp4?dl=0
      Cr4z33C 2 Replies Last reply Reply Quote 0
      • Cr4z33C
        Cr4z33 @sdetweil
        • Cr4z33C
          Cr4z33 @sdetweil
            I don’t understand. the default, the text ( the beginning of the line of text) starts to appear on the right side of the screen and scrolls to the left ( last showing the end of the line of text)
            my change, per your request, the end of the text appears on the left of the screen, and scrolls to the right ( last showing the beginning of the line of text)
            this is for left to right language English. I don’t know if language setting changes the default marquee order
              @Cr4z33 did u see my post above?
              • Cr4z33C
                Cr4z33 @sdetweil
                @sdetweil said in [MMM-NewsFeedTicker] scroll from left to right only?:
                Yep saw also the video.
                Dunno why my MM system ignores the CSS edit… :confounded_face:
                  sdetweil @Cr4z33
                  @Cr4z33 do you have a custom.css setting which would override the module?
                  • Cr4z33C
                    Cr4z33 @sdetweil
                    @sdetweil indeed so that’s the reason then?? :anguished_face:
                    Update:
                    Nope it keeps going back and forth even without custom.css entry…
                      sdetweil @Cr4z33
                      @Cr4z33 did u delete custom.css, comment out or what?
                      and restarted MM
                      • Cr4z33C
                        Cr4z33 @sdetweil
                        @sdetweil I deleted the file.
                        Yes I restarted MM.
                          sdetweil @Cr4z33
                          @Cr4z33 that is
                          ~/MagicMirror/css/custom.css
                          right?
                          and u edited the MMM-NewsFeedTicker.css in the MMM-NewsFeedTicker module folder to add my changes, yes?
                          • Cr4z33C
                            Cr4z33 @sdetweil
                            @Cr4z33 that is
                            right?
                            Correct. 👍🏽
                              sdetweil @Cr4z33
                              @Cr4z33 the module is still requesting to load the css directly, right? with the right name
                                  getStyles: function() {
                                      return ["MMM-NewsFeedTicker.css"];
                              one more thing, my module is running all default values, cause i changed the name of the default newsfeed module to this one… but did NOT set any config values…
                              			module: "MMM-NewsFeedTicker",
                              			position: "bottom_bar",
                              				feeds: [
                              						title: "New York Times",
                              				showSourceTitle: true,
                              				showPublishDate: true,
                              				broadcastNewsFeeds: true,
                              				broadcastNewsUpdates: true
                              • Cr4z33C
                                Cr4z33 @sdetweil
                                @sdetweil I tried using your defaults as well by getting the issue again.
                                At this point could Debian 10 running (natively of course) on an Intel NUC be the problem?
                                  sdetweil @Cr4z33
                                  @Cr4z33 I’m doing this on Intel.
                                  rename your MMM-NewsFeedTicker folder out of the way and clone my fork
                                  https://github.com/sdetweil/MMM-NewsFeedTicker
                                  Cr4z33C 1 Reply Last reply Reply Quote 1
                                  • Cr4z33C
                                    Cr4z33 @sdetweil
                                    @sdetweil cheers going to do it as soon as I am done with reinstalling Debian (stupid issue with USB mics not detected anymore…)! 👍🏽
                                    I will reply here.
                                    • Cr4z33C
                                      Cr4z33
                                      @sdetweil I’ve installed your fork and… it’s going back and forth too! :smiling_face_with_open_mouth_cold_sweat:
                                      Here’s my module config just in case:
                                      			disabled: false,
                                      			//classes: "day_scheduler",
                                      					feeds: [
                                      							title: "Cambio Euro/Dollaro",
                                      							url: "https://eur.fxexchangerate.com/usd.xml",
                                      							customLogo: "xe.png"
                                      							title: "Agenzia ANSA - Ultima Ora",
                                      							url: "https://www.ansa.it/sito/notizie/topnews/topnews_rss.xml",
                                      							customLogo: "ansa.jpg"
                                      							title: "La Gazzetta del Mezzogiorno - Lecce",
                                      							url: "https://www.lagazzettadelmezzogiorno.it/rss.jsp?sezione=113",
                                      							customLogo: "gdm.jpg"
                                      							title: "Hardware Upgrade",
                                      							url: "https://feeds.hwupgrade.it/rss_hwup.xml",
                                      							customLogo: "hwu.png"
                                      							title: "HDblog.it",
                                      							url: "http://feeds.feedburner.com/hd-blog?format=xml",
                                      							customLogo: "hdblog.png"
                                      							title: "Tom's Hardware",
                                      							url: "https://www.tomshw.it/feed/",
                                      							customLogo: "tomshw.png"
                                      							title: "Punto Informatico",
                                      							url: "https://www.punto-informatico.it/feed/",
                                      							customLogo: "pi.png"
                                      							title: "LeccePrima",
                                      							url: "http://www.lecceprima.it/rss/",
                                      							customLogo: "lecceprima.png"
                                      							title: "Galatina.it",
                                      							url: "http://www.galatina.it/rss.xml",
                                      							customLogo: "galatina.png"
                                        sdetweil @Cr4z33
                                        @Cr4z33 so, u have some custom class somewhere.
                                        • Cr4z33C
                                          Cr4z33 @sdetweil
                                          @sdetweil OK where should I look at please ? 😅
                                            sdetweil @Cr4z33
                                            @Cr4z33 no… idea… I would reinstall MM (use my script), just rename the old MM folder to something else,
                                            then install my module version to verify
                                            then u can start looking around… i installed from scratch like that to test before I sent to you, and others have confirmed it works for them too.
                                            Cr4z33C ? 2 Replies Last reply Reply Quote 0
                                            • 2 / 3
