    [MMM-NewsFeedTicker] scroll from left to right only?
    41 Posts 3 Posters 15.7k Views 4 Watching
    • Cr4z33C Offline
      Cr4z33 @sdetweil
      @sdetweil I tried using your defaults as well by getting the issue again.
      At this point could Debian 10 running (natively of course) on an Intel NUC be the problem?
        sdetweil @Cr4z33
        @Cr4z33 I’m doing this on Intel.
        rename your MMM-NewsFeedTicker folder out of the way and clone my fork
        https://github.com/sdetweil/MMM-NewsFeedTicker
        Cr4z33C 1 Reply Last reply Reply Quote 1
        • Cr4z33C Offline
          Cr4z33 @sdetweil
          @sdetweil cheers going to do it as soon as I am done with reinstalling Debian (stupid issue with USB mics not detected anymore…)! 👍🏽
          I will reply here.
          • Cr4z33C Offline
            Cr4z33
            @sdetweil I’ve installed your fork and… it’s going back and forth too! :smiling_face_with_open_mouth_cold_sweat:
            Here’s my module config just in case:
            			module: "MMM-NewsFeedTicker",
            			disabled: false,
            			position: "bottom_bar",
            			//classes: "day_scheduler",
            					feeds: [
            							title: "Cambio Euro/Dollaro",
            							url: "https://eur.fxexchangerate.com/usd.xml",
            							customLogo: "xe.png"
            							title: "Agenzia ANSA - Ultima Ora",
            							url: "https://www.ansa.it/sito/notizie/topnews/topnews_rss.xml",
            							customLogo: "ansa.jpg"
            							title: "La Gazzetta del Mezzogiorno - Lecce",
            							url: "https://www.lagazzettadelmezzogiorno.it/rss.jsp?sezione=113",
            							customLogo: "gdm.jpg"
            							title: "Hardware Upgrade",
            							url: "https://feeds.hwupgrade.it/rss_hwup.xml",
            							customLogo: "hwu.png"
            							title: "HDblog.it",
            							url: "http://feeds.feedburner.com/hd-blog?format=xml",
            							customLogo: "hdblog.png"
            							title: "Tom's Hardware",
            							url: "https://www.tomshw.it/feed/",
            							customLogo: "tomshw.png"
            							title: "Punto Informatico",
            							url: "https://www.punto-informatico.it/feed/",
            							customLogo: "pi.png"
            							title: "LeccePrima",
            							url: "http://www.lecceprima.it/rss/",
            							customLogo: "lecceprima.png"
            							title: "Galatina.it",
            							url: "http://www.galatina.it/rss.xml",
            							customLogo: "galatina.png"
              sdetweil @Cr4z33
              @Cr4z33 so, u have some custom class somewhere.
              • Cr4z33C Offline
                Cr4z33 @sdetweil
                @sdetweil OK where should I look at please ? 😅
                  sdetweil @Cr4z33
                  @Cr4z33 no… idea… I would reinstall MM (use my script), just rename the old MM folder to something else,
                  then install my module version to verify
                  then u can start looking around… i installed from scratch like that to test before I sent to you, and others have confirmed it works for them too.
                  Cr4z33C ? 2 Replies Last reply Reply Quote 0
                  • Cr4z33C Offline
                    Cr4z33 @sdetweil
                    @sdetweil okie dokie I am going to reinstall both Debian and MM too in the next days because of other issues.
                    I will reply here thanks.
                      A Former User @sdetweil
                      Confirmed works with Debian dev desktop
                        A Former User @Cr4z33
                        @Cr4z33 said in [MMM-NewsFeedTicker] scroll from left to right only?:
                        I don’t understand why reinstall all ecosystem. but it’s your choice ;)
                          sdetweil @Guest
                          @Bugsounet he said “because of other issues.”
                            A Former User
                            fortunately I don’t reinstall debian with each problem … otherwise I will not get out!
                            Usually the problem comes from the MM directory, I think
                            because with debian some permission missing
                            • Cr4z33C Offline
                              Cr4z33 @Guest
                              @Bugsounet neither do I usually, but all solutions found around have failed.
                              USB microphones do not get detected anymore from one day to another… 🤷🏽‍♂️
                              Of course they work perfectly if ie. I connect them to my Windows 10 computer.
                              • 2 / 3
