    Time and Weather problems
    15 Posts 2 Posters 3.3k Views 2 Watching
      sdetweil @Vaughn
      @Vaughn you didn’t open an issue, just a topic. so it can’t be closed/resolved
      can u clarify the problem with the dateFormat field. why you couldn’t solve this on your own.
      maybe we need to fix something in the doc, or something else.
      the intent is to give users, even those with limited experience, access to clear and direct info, so that they don’t become disillusioned with some of the complexities.
      • V Offline
        Vaughn
        The issue was I used the wrong call for the key. This I think was as I had been trying so many, I had got stuck on this city.list.json file I could not open. the original code insists it is required for your location. I’m still not fully sure I have the correct location.
        To get mine:
        I first went to the MMM world map site.
        Here I saw a full map with all the cities and their weather locations. Mine was 35, I think, Ipswich
        I added this to my code. I also added the Lon and Lat, hoping they would take the correct info.
        The forecast looks OK, similar to that on the TV earlier, so maybe I got it correct.
        this is my working code:
        module: “MMM-3Day-Forecast”,
        position: “bottom_left”,
        header: “3 Day forecast”,
        locationID: “35”, //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
        api_key: “correct call for key”, // weatherbit
        //appid: “Old call for key”,
        lat: 52.062569,
        long: 1.233907,
        units: “M”,
        lang: “en”,
        interval: 900000
        Now the LocationID:“”, I got from a map. No idea where this was from, cant find it again, but think its OK. If it is wrong please let me know.
        Main area Of problem I had was in reading the city.list.json file. Does this need a program to read? as noting I found would open it. I presume, there is a program/code you can use that finds the locationID with just the city name or, Long/Lat numbers?
        this is the area I feel needs a little more explanation for novices like me please :-)
        Hope this helps Vaughn
          sdetweil @Vaughn
          @Vaughn once again, that module, MMM-3Day-Forecast, doesn’t use the city list file, so it doesn’t matter.
          but, net, you appear not to be reading the documentation for the modules you are using. ( the module that DOES use the file gives instructions, which h u have copied, but still not read)
          • V Offline
            Vaughn
            the gz file I did try to unzip, but this was on the PC, Win10, and this failed.
            Sis not know the code/way to unzip in the pi.
            Did read the notes, but then understanding is another thing. Missing a comer, is sooo important, but not seen, if not known it should be there. Your comment, ;more comers;, was the key thanks
              sdetweil @Vaughn
              @Vaughn
              did u ask anyone? that exact phrase on Google would have got u the answer.
              I still haven’t answered on the actual date format problem
