    MMM-XboxFriends - Using Puppeteer to retrieve your xbox friends list and their status
    11 Posts 3 Posters 4.7k Views 3 Watching
    • K Offline
      kfyfeg
      this is my first module so please, if you’re interested, try it and tell me what you think!
      Download and instructions on GitHub.
      Example
      alt text
        steve8384 @kfyfeg
        @kfyfeg Hello there ! I love this concept and thanks for taking the time out to do this. I can get as far as Login OK when running MMM-XboxFriends but then it doesnt show anything. I used option 2 for setting login credentials… any idea on what the issue is ?
        Steve -
        • K Offline
          kfyfeg @steve8384
          @steve8384 hi! Thanks for trying this module!
          Can you try using debug:true and copy what appears in the console?
          You can also try with showBrowser: false and see where it get stuck
            steve8384
            Hello - this is what I get from the debug console.
            [2020-09-05 15:52:31.772] [LOG] Core start
            [2020-09-05 15:52:31.774] [LOG] Core getDom
            [2020-09-05 15:52:31.776] [LOG] loaded: false
            [2020-09-05 15:52:31.778] [LOG] Helper notification CONFIG
            [2020-09-05 15:52:31.784] [LOG] Launching puppeteer…
            [2020-09-05 15:52:31.787] [LOG] loginCache:
            [2020-09-05 15:52:31.789] [LOG] loginFinal: true
            [2020-09-05 15:52:31.790] [LOG] already logged in
            [2020-09-05 15:52:31.928] [LOG] Core getDom
            [2020-09-05 15:52:31.932] [LOG] loaded: false
            [2020-09-05 15:52:33.853] [INFO] Newsfeed-Fetcher: Broadcasting 59 items.
            [2020-09-05 15:52:37.803] [LOG] userdata: /home/pi/MagicMirror/modules/MMM-XboxFriends/myUserDataDir/
            [2020-09-05 15:52:44.476] [LOG] loginCache:
            [2020-09-05 15:52:44.481] [LOG] Login OK…
            [2020-09-05 15:52:44.493] [LOG] Searching list…
            [2020-09-05 15:52:44.580] [LOG] XXX core socketNotificationReceived: LOGIN_OK
            [2020-09-05 15:52:44.592] [LOG] Core getDom
            [2020-09-05 15:52:44.608] [LOG] loaded: false
            [2020-09-05 15:52:54.522] [LOG] List not found, refreshing…
            [2020-09-05 15:52:59.743] [LOG] Num. amigos: 0
            [2020-09-05 15:52:59.748] [LOG] []
            [2020-09-05 15:52:59.751] [LOG] largo array: 0
            [2020-09-05 15:52:59.794] [LOG] XXX core socketNotificationReceived: INFO_OK
            [2020-09-05 15:52:59.803] [LOG] Core getDom
            [2020-09-05 15:52:59.813] [LOG] loaded: true
            [2020-09-05 15:52:59.830] [LOG] largo array: 0
            [2020-09-05 15:52:59.837] [LOG] config.maxEntries: 7
            [2020-09-05 15:52:59.843] [LOG] config.offline: true
            [2020-09-05 15:52:59.848] [LOG] config.fadePoint: 0.5
            [2020-09-05 15:53:00.933] [LOG] Puppeteer closed…
            • K Offline
              kfyfeg @steve8384
              @steve8384 hi! I’ll review the code to try to find the bug.
              You can also try showBrowser: true to see if puppeteer can access your friend list or some problem appears in between
              • C Offline
                Commander
                Big Thanks for this Plugin,
                I have a Problem after use node generateLogin.js.
                Are you already logged in?
                No, please login
                user OK
                pass OK
                TimeoutError: waiting for selector #primaryArea > core-area > core-region-pivot > section > section > header > a.f-active failed: timeout 40000ms exceeded
                at new WaitTask (/home/pi/MagicMirror/modules/MMM-Xboxfriends/node_modules/puppeteer/lib/cjs/puppeteer/common/DOMWorld.js:526:34)
                at DOMWorld.waitForSelectorInPage (/home/pi/MagicMirror/modules/MMM-Xboxfriends/node_modules/puppeteer/lib/cjs/puppeteer/common/DOMWorld.js:430:26)
                at Object.internalHandler.waitFor (/home/pi/MagicMirror/modules/MMM-Xboxfriends/node_modules/puppeteer/lib/cjs/puppeteer/common/QueryHandler.js:31:77)
                at DOMWorld.waitForSelector (/home/pi/MagicMirror/modules/MMM-Xboxfriends/node_modules/puppeteer/lib/cjs/puppeteer/common/DOMWorld.js:321:29)
                at Frame.waitForSelector (/home/pi/MagicMirror/modules/MMM-Xboxfriends/node_modules/puppeteer/lib/cjs/puppeteer/common/FrameManager.js:925:51)
                at Page.waitForSelector (/home/pi/MagicMirror/modules/MMM-Xboxfriends/node_modules/puppeteer/lib/cjs/puppeteer/common/Page.js:2359:33)
                at /home/pi/MagicMirror/modules/MMM-Xboxfriends/generateLogin.js:46:14
                at processTicksAndRejections (internal/process/task_queues.js:95:5)
                I hope you can help :-)
                • K Offline
                  kfyfeg @Commander
                  @commander Hi! Thanks for trying this module!
                  Because I’m using Puppeteer, a little change in the site structure may result in an error. As soon as I can I’ll review the code to find a solution. I’ll let you know
                  Cheers!
                  C 2 Replies Last reply Reply Quote 0
                  • C Offline
                    Commander @kfyfeg
                    @kfyfeg Big Thanks this would be great.
                    Did MagicMirro use the same Browser as puppeteer?
                    • K Offline
                      kfyfeg @Commander
                      @commander I understand that it use the same browser but a different instance/session
                      • C Offline
                        Commander @kfyfeg
                        @kfyfeg
                        Did you run the Plugin at the moment on your MM?
                        You wrote at GitHub this:
                        Option 1: Manual login
                        Go to MMM-XboxFriends folder
                        cd ~/MagicMirror/modules/MMM-GooglePhotos
                        Its an Misstake with MMM-GooglePhotos? You mean MMM-XboxFriends?
