    Raspbian/MM won't boot
    4 Posts 2 Posters 844 Views 2 Watching
    • C Offline
      Cyric
      Hi Everyone,
      Things had been going well for the magic mirror. Everything updated, motion sensor worked, it was great. Yesterday I noticed it was off. I rebooted it, and it went from the 4 raspberries on top, to the magic mirror boot screen, to the screen down in the pictures. I keep restarting, and it seems to give me a different message each time. The only common thing is chmod: cannot access ‘monitor_o*’ no such file or directory. I’m not sure what happened. I haven’t messed with it since it started running except to do some updates, I haven’t added any new modules. It will stay on this screen and repeat the same lines over and over until I turn it off.
      Pictures:
      alt text
      alt text
      alt text
      alt text
      alt text
      Thank you!
        sdetweil @Cyric
        @Cyric it’s the same message. file not found.
        this typically means some problem w the SD card, if it was working before.
        they are quite fragile
        • C Offline
          Cyric
          Thanks. Is there any way to save the files on there? I hooked the card to my windows machine and copied everything.
            sdetweil @Cyric
            @Cyric if u copied everything, then u should be ok…
            reflash the card
            u will have to do another install cycle to get all the dependencies redone…
            run the installer script again…
            then copy your modules folder over and the config.js
            i don’t know what was trying to do the monitor_on*
