    Cant start after update 2.13
    12 Posts 2 Posters 1.4k Views 2 Watching
      sdetweil @SuseGigabyte
      @SuseGigabyte lets try to recover
      do
      cd ~/MagicMirror
      npm install electron@6.1.7
      then try to restart mm… there may be other problems to solve
        SuseGigabyte
        after command: npm install electron@6.1.7
        the following message appears:
        npm ERR! Unexpected end of JSON input while parsing near '… “p-locate”: {
        npm ERR! ’
        npm ERR! /home/pi/.npm/_logs/2020-10-04T16_40_18_667Z-debug.log
        after restart mm
        magicmirror@2.13.0 start /home/pi/MagicMirror
        DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
        sh: 1: ./node_modules/.bin/electron: not found
        npm ERR! code ELIFECYCLE
        npm ERR! syscall spawn
        npm ERR! file sh
        npm ERR! errno ENOENT
        npm ERR! magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
        npm ERR! spawn ENOENT
        npm ERR!
        npm ERR! Failed at the magicmirror@2.13.0 start script.
        npm WARN Local package.json exists, but node_modules missing, did you mean to install?
        npm ERR! /home/pi/.npm/_logs/2020-10-04T16_43_10_392Z-debug.log
          @SuseGigabyte what pi is this?
          also, show me the output of
          lsb_release -a
          uname -a
          node -v
          npm -v
            SuseGigabyte
            @sdetweil thank you for your patience.
            Raspberry Pi 3 Model B Plus Rev 1.3
            pi@raspberrypi:~/MagicMirror $ lsb_release -a
            No LSB modules are available.
            Distributor ID: Raspbian
            Description: Raspbian GNU/Linux 10 (buster)
            pi@raspberrypi:~/MagicMirror $ uname -a
            Linux raspberrypi 5.4.51-v7+ #1333 SMP Mon Aug 10 16:45:19 BST 2020 armv7l GNU/Linux
            pi@raspberrypi:~/MagicMirror $ node -v
            v10.22.1
            pi@raspberrypi:~/MagicMirror $ npm -v
            6.10.3
              @SuseGigabyte hmmm… looks ok,
              i ‘suspect’ a bad sd card, but lets try one more time using my upgrade script
              from here
              execute this
              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
              it will create a log file, MagicMirror/installers/upgrade.log
                SuseGigabyte
                @sdetweil You’re a genius. I can’t thank you enough.
                After hours of blood, sweat and almost tears every thing went o.k.
                Do I have to do an additional command because of:
                added 394 packages from 287 contributors and audited 1163 packages in 412.313s
                found 3 low severity vulnerabilities
                  run `npm audit fix` to fix them, or `npm audit` for details
                npm install completed - So Okt  4 19:08:08 CEST 2020 on base
                **upgrade.log**
                Upgrade started - So Okt  4 19:00:18 CEST 2020
                system is Linux raspberrypi 5.4.51-v7+ #1333 SMP Mon Aug 10 16:45:19 BST 2020 armv7l GNU/Linux
                the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                user requested to force apply changes
                doing test run = false
                saving custom.css
                remote name = origin
                upgrading from version 2.13.0 to 2.13.0
                fetching latest revisions
                git fetch rc=0
                current branch = master
                On branch master
                Your branch is up to date with 'origin/master'.
                Changes not staged for commit:
                  (use "git add/rm <file>..." to update what will be committed)
                  (use "git checkout -- <file>..." to discard changes in working directory)
                	deleted:    config/config.js.sample
                	modified:   installers/mm.sh
                	deleted:    modules/default/clock/README.md
                	modified:   modules/default/clock/clock.js
                	deleted:    modules/default/clock/clock_styles.css
                	modified:   modules/default/compliments/compliments.js
                	modified:   package-lock.json
                	modified:   package.json
                Untracked files:
                  (use "git add <file>..." to include in what will be committed)
                	core
                	css/custom.css_Back
                	css/custom.css_Backup
                	css/save_custom.css
                	installers/pm2_MagicMirror.json
                	js/socketclient.js_heute
                	js/socketclient.js_mod
                	js/socketclient.js_modified
                	js/socketclient.js_org
                	modules/default/back_clock/
                	modules/default/compliments/compliments.js_org
                	package-lock.json_back
                	package-lock.json_back_1
                	package.json_back
                	package.json_back_1
                no changes added to commit (use "git add" and/or "git commit -a")
                there are 5 local files that are different than the master repo
                   installers/mm.sh
                   package-lock.json
                   package.json
                save/restore files selection = y
                Speicherte Arbeitsverzeichnis und Index-Status WIP on master: 3dbe8bf Merge pull request #2143 from MichMich/develop
                test merge result rc='' , if empty, no conflicts
                executing merge, apply specified
                merge result rc= 0
                 Already up to date.
                processor architecture is armv7l
                updating MagicMirror runtime, please wait
                > console-stamp@0.2.9 postinstall /home/pi/MagicMirror/node_modules/console-stamp
                > node ./msg.js
                Attention
                    Console-stamp version 3.0.0 Release Candidate is out. Install by using the tag '@next'. NB: Breaking changes.
                    For more details goto: https://www.npmjs.com/package/console-stamp/v/next
                > electron@6.1.12 postinstall /home/pi/MagicMirror/node_modules/electron
                > node install.js
                > magicmirror@2.13.0 install /home/pi/MagicMirror
                > echo "Installing vendor files ...
                " && cd vendor && npm install --loglevel=error
                audited 24 packages in 2.478s
                found 0 vulnerabilities
                > magicmirror@2.13.0 postinstall /home/pi/MagicMirror
                > npm run install-fonts && echo "MagicMirror installation finished successfully!
                > magicmirror@2.13.0 install-fonts /home/pi/MagicMirror
                > echo "Installing fonts ...
                " && cd fonts && npm install --loglevel=error
                audited 1 package in 2.715s
                fixing sandbox permissions
                downloading dumpactivemodules script
                processing dependency changes for active modules with package.json files
                processing for module netatmo please wait
                  @SuseGigabyte no additional commands required
                  in the future, please use code wrapper for posts with messages like this… (mark the text and hit the </> button)
                    SuseGigabyte
                    @sdetweil I’m sorry about that. I didn’t know that.:face_with_hand_over_mouth: #beginner
                      @SuseGigabyte no problem, see https://forum.magicmirror.builders/topic/67/forum-posting-tips?_=1601749531385
