    last update stop my MM
    17 Posts 2 Posters 3.7k Views 2 Watching
    • X Offline
      xaba
      just tried do update my MM and all stop working!! try already reinstall and keep not working, nothing happened, when starts!! what can i do??
        sdetweil @xaba
        @xaba a little more info…
        how did you try to update, what was the behavior?
        try reinstall … however u start MM
        if npm start
        some the messages in the terminal window where u start MM
        if pm2, then use the pm2 logs --lines=??? command to get the info
        ??? is a number 15 is the default (which may not display enough)
        • X Offline
          xaba
          hi @sdetweil !!
          i use this line to update my MM…
          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
          after that my Pi stops working, and frozen the screen, next day, i saw the screen shows the same time and date when i did the update. reboot and no longer works…
          already try reinstall it but didnt work as well, so i dont know what to do!!
          MM doesnt auto start!!
          just try to execute mm.sh and shows me this:
          pi@magicpi:~/MagicMirror/installers $ ./mm.sh
          magicmirror@2.13.0 start /home/pi/MagicMirror
          DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
          sh: 1: ./node_modules/.bin/electron: not found
          npm ERR! code ELIFECYCLE
          npm ERR! syscall spawn
          npm ERR! file sh
          npm ERR! errno ENOENT
          npm ERR! magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
          npm ERR! spawn ENOENT
          npm ERR!
          npm ERR! Failed at the magicmirror@2.13.0 start script.
          npm ERR! /home/pi/.npm/_logs/2020-10-15T13_27_37_850Z-debug.log
            sdetweil @xaba
            @xaba ok, little more info… is this a pi0?
            can u send me the ~/MagicMirror/installers/upgrade.log
            (I think you deleted in on reinstall)
            how did u reinstall??
            did you use my installer script?
            if so, send the ~/install.log file
              @xaba also, you didn’t respond to the topic
              run-start.sh: linha 87
              • X Offline
                xaba
                is a Pi3 model B+
                when i try to reinstall it, yes, i deleted MagicMirror folder. after that reinstall with this line:
                bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
                and dont have this install.log in MM Folder!!
                  sdetweil @xaba
                  @xaba ~/install.log
                  the install.log in the users home folder (~)
                  /home/pi/install.log
                  ~=/home/pi for user pi
                  my email is the same userid at gmail
                  • X Offline
                    xaba
                    ok!!
                    gonna email you the log file!!
                    • X Offline
                      xaba
                      receive it??
                      just reinstall new MM!!
                      • X Offline
                        xaba
                        this appear in new resintall:
                        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                        npm WARN deprecated rrule-alt@2.2.8: Please use rrule instead
                        npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart()
                        npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                        npm WARN deprecated webdriverio@4.14.4: outdated version, please use @next
                        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                        npm WARN deprecated core-js@2.6.11: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
                        npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                        npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                        /home/pi/MagicMirror/node_modules/electron/install.js:53
                        throw err
                        Error: Could not parse checksum file at line 1:
                        at data.trim.split.forEach.line (/home/pi/MagicMirror/node_modules/sumchecker/index.js:85:18)
                        at Array.forEach ()
                        at Promise (/home/pi/MagicMirror/node_modules/sumchecker/index.js:80:36)
                        at new Promise ()
                        at ChecksumValidator.parseChecksumFile (/home/pi/MagicMirror/node_modules/sumchecker/index.js:76:12)
                        npm notice created a lockfile as package-lock.json. You should commit this file.
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.1 (node_modules/chokidar/node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
                        npm WARN mocha-logger@1.0.7 requires a peer of mocha@^8.1.3 but none is installed. You must install peer dependencies yourself.
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@6.1.12 (node_modules/electron):
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@6.1.12 postinstall: node install.js
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                        Dependencies installation Done!
                          sdetweil @xaba
                          @xaba ok, try
                          cd ~/MagicMirror
                          npm install  electron@6.1.12
                          S X 2 Replies Last reply Reply Quote 0
                            @xaba I don’t seen anything troubling in the log file…
                            • X Offline
                              xaba @sdetweil
                              electron@6.1.12 postinstall /home/pi/node_modules/electron
                              node install.js
                              Downloading tmp-6080-0-electron-v6.1.12-linux-armv7l.zip
                              [============================================>] 100.0% of 54.85 MB (3.99 MB/s)
                              /home/pi/node_modules/electron/install.js:53
                              throw err
                              at data.trim.split.forEach.line (/home/pi/node_modules/sumchecker/index.js:85:18)
                              at Array.forEach ()
                              at Promise (/home/pi/node_modules/sumchecker/index.js:80:36)
                              at new Promise ()
                              at ChecksumValidator.parseChecksumFile (/home/pi/node_modules/sumchecker/index.js:76:12)
                              npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                              npm WARN pi No description
                              npm WARN pi No repository field.
                              npm WARN pi No README data
                              npm WARN pi No license field.
                              npm ERR! errno 1
                              npm ERR! electron@6.1.12 postinstall: node install.js
                              npm ERR! Exit status 1
                              npm ERR!
                              npm ERR! Failed at the electron@6.1.12 postinstall script.
                              npm ERR! /home/pi/.npm/_logs/2020-10-15T22_33_52_461Z-debug.log
                                sdetweil @xaba
                                @xaba said in last update stop my MM:
                                looks like network error, try again
                                do
                                cd ~/MagicMirror
                                rm -rf node_modules/electron
                                I tested here and it worked ok
                                X 1 Reply Last reply Reply Quote 0
                                • X Offline
                                  xaba @sdetweil
                                  not worked!!
                                  gonna rebuild the system pi, download again MM!!
                                    sdetweil @xaba
                                    @xaba use my script
                                    see here for instructions
                                    https://github.com/sdetweil/magicmirror_scripts
                                    • X Offline
                                      xaba
                                      gonna use it!! thks!!
