last update stop my MM
17 Posts 2 Posters 2.3k Views 2 Watching
  • X Offline
    xaba
    just tried do update my MM and all stop working!! try already reinstall and keep not working, nothing happened, when starts!! what can i do??
    S 1 Reply Last reply Oct 14, 2020, 4:10 PM Reply Quote 0
      sdetweil @xaba
      @xaba a little more info…
      how did you try to update, what was the behavior?
      try reinstall … however u start MM
      if npm start
      some the messages in the terminal window where u start MM
      if pm2, then use the pm2 logs --lines=??? command to get the info
      ??? is a number 15 is the default (which may not display enough)
      • X Offline
        xaba
        hi @sdetweil !!
        i use this line to update my MM…
        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
        after that my Pi stops working, and frozen the screen, next day, i saw the screen shows the same time and date when i did the update. reboot and no longer works…
        already try reinstall it but didnt work as well, so i dont know what to do!!
        MM doesnt auto start!!
        just try to execute mm.sh and shows me this:
        pi@magicpi:~/MagicMirror/installers $ ./mm.sh
        magicmirror@2.13.0 start /home/pi/MagicMirror
        sh: 1: ./node_modules/.bin/electron: not found
        npm ERR! code ELIFECYCLE
        npm ERR! syscall spawn
        npm ERR! file sh
        npm ERR! errno ENOENT
        npm ERR! magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
        npm ERR! spawn ENOENT
        npm ERR!
        npm ERR! Failed at the magicmirror@2.13.0 start script.
        npm ERR! /home/pi/.npm/_logs/2020-10-15T13_27_37_850Z-debug.log
        S 1 Reply Last reply Oct 15, 2020, 1:34 PM Reply Quote 0
          sdetweil @xaba
          @xaba ok, little more info… is this a pi0?
          can u send me the ~/MagicMirror/installers/upgrade.log
          (I think you deleted in on reinstall)
          how did u reinstall??
          did you use my installer script?
          if so, send the ~/install.log file
          S 1 Reply Last reply Oct 15, 2020, 1:35 PM Reply Quote 0
            @xaba also, you didn’t respond to the topic
            run-start.sh: linha 87
            • X Offline
              xaba
              is a Pi3 model B+
              when i try to reinstall it, yes, i deleted MagicMirror folder. after that reinstall with this line:
              bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
              and dont have this install.log in MM Folder!!
              S 1 Reply Last reply Oct 15, 2020, 1:42 PM Reply Quote 0
                sdetweil @xaba
                @xaba ~/install.log
                the install.log in the users home folder (~)
                /home/pi/install.log
                ~=/home/pi for user pi
                my email is the same userid at gmail
                • X Offline
                  xaba
                  ok!!
                  gonna email you the log file!!
                  • X Offline
                    xaba
                    receive it??
                    just reinstall new MM!!
                    • X Offline
                      xaba
                      this appear in new resintall:
                      npm WARN deprecated rrule-alt@2.2.8: Please use rrule instead
                      npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart()
                      npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                      npm WARN deprecated webdriverio@4.14.4: outdated version, please use @next
                      npm WARN deprecated core-js@2.6.11: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
                      npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                      npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                      /home/pi/MagicMirror/node_modules/electron/install.js:53
                      throw err
                      Error: Could not parse checksum file at line 1:
                      at data.trim.split.forEach.line (/home/pi/MagicMirror/node_modules/sumchecker/index.js:85:18)
                      at Array.forEach ()
                      at Promise (/home/pi/MagicMirror/node_modules/sumchecker/index.js:80:36)
                      at new Promise ()
                      at ChecksumValidator.parseChecksumFile (/home/pi/MagicMirror/node_modules/sumchecker/index.js:76:12)
                      npm notice created a lockfile as package-lock.json. You should commit this file.
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.1 (node_modules/chokidar/node_modules/fsevents):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
                      npm WARN mocha-logger@1.0.7 requires a peer of mocha@^8.1.3 but none is installed. You must install peer dependencies yourself.
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@6.1.12 (node_modules/electron):
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@6.1.12 postinstall: node install.js
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                      Dependencies installation Done!
                      S 1 Reply Last reply Oct 15, 2020, 2:05 PM Reply Quote 0
