    last update stop my MM
    17 Posts 2 Posters 3.4k Views 2 Watching
    • X Offline
      xaba
      is a Pi3 model B+
      when i try to reinstall it, yes, i deleted MagicMirror folder. after that reinstall with this line:
      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
      and dont have this install.log in MM Folder!!
        sdetweil @xaba
        @xaba ~/install.log
        the install.log in the users home folder (~)
        /home/pi/install.log
        ~=/home/pi for user pi
        my email is the same userid at gmail
        • X Offline
          xaba
          ok!!
          gonna email you the log file!!
          • X Offline
            xaba
            receive it??
            just reinstall new MM!!
            • X Offline
              xaba
              this appear in new resintall:
              npm WARN deprecated rrule-alt@2.2.8: Please use rrule instead
              npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart()
              npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
              npm WARN deprecated webdriverio@4.14.4: outdated version, please use @next
              npm WARN deprecated core-js@2.6.11: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
              npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
              npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
              /home/pi/MagicMirror/node_modules/electron/install.js:53
              throw err
              Error: Could not parse checksum file at line 1:
              at data.trim.split.forEach.line (/home/pi/MagicMirror/node_modules/sumchecker/index.js:85:18)
              at Array.forEach ()
              at Promise (/home/pi/MagicMirror/node_modules/sumchecker/index.js:80:36)
              at new Promise ()
              at ChecksumValidator.parseChecksumFile (/home/pi/MagicMirror/node_modules/sumchecker/index.js:76:12)
              npm notice created a lockfile as package-lock.json. You should commit this file.
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.1 (node_modules/chokidar/node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
              npm WARN mocha-logger@1.0.7 requires a peer of mocha@^8.1.3 but none is installed. You must install peer dependencies yourself.
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@6.1.12 (node_modules/electron):
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@6.1.12 postinstall: node install.js
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
              Dependencies installation Done!
                sdetweil @xaba
                @xaba ok, try
                npm install  electron@6.1.12
                S X 2 Replies Last reply Reply Quote 0
                  @xaba I don’t seen anything troubling in the log file…
                  • X Offline
                    xaba @sdetweil
                    electron@6.1.12 postinstall /home/pi/node_modules/electron
                    node install.js
                    Downloading tmp-6080-0-electron-v6.1.12-linux-armv7l.zip
                    [============================================>] 100.0% of 54.85 MB (3.99 MB/s)
                    /home/pi/node_modules/electron/install.js:53
                    throw err
                    at data.trim.split.forEach.line (/home/pi/node_modules/sumchecker/index.js:85:18)
                    at Array.forEach ()
                    at Promise (/home/pi/node_modules/sumchecker/index.js:80:36)
                    at new Promise ()
                    at ChecksumValidator.parseChecksumFile (/home/pi/node_modules/sumchecker/index.js:76:12)
                    npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                    npm WARN pi No description
                    npm WARN pi No repository field.
                    npm WARN pi No README data
                    npm WARN pi No license field.
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 1
                    npm ERR! electron@6.1.12 postinstall: node install.js
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the electron@6.1.12 postinstall script.
                    npm ERR! /home/pi/.npm/_logs/2020-10-15T22_33_52_461Z-debug.log
                      sdetweil @xaba
                      @xaba said in last update stop my MM:
                      looks like network error, try again
                      do
                      rm -rf node_modules/electron
                      I tested here and it worked ok
                      X 1 Reply Last reply Reply Quote 0
                      • X Offline
                        xaba @sdetweil
                        not worked!!
                        gonna rebuild the system pi, download again MM!!
                          sdetweil @xaba
                          @xaba use my script
                          see here for instructions
                          https://github.com/sdetweil/magicmirror_scripts
                          • X Offline
                            xaba
                            gonna use it!! thks!!
