    PIR Motion Detection - White Screen
    1 Posts 1 Posters 1.1k Views 1 Watching
    • T
      Them Russians
      When I try to run an “npm install” on the “MMM-PIR-Sensor” directory, i get the following error. Does anyone know what could be causing this, and go to resolve it? I am able to run the rest of the mirror, along with some other modules from this site without issue.
      Here is the error:
      Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /home/pi/MagicMirror/modules/MMM-PIR-Sensor
      electron-rebuild -e …/…/node_modules/electron-prebuilt
      An unhandled error occurred inside electron-rebuild
      Unable to find electron-prebuilt’s version number, either install it or specify an explicit version
      Error: Unable to find electron-prebuilt’s version number, either install it or specify an explicit version
      at _callee$ (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:74:17)
      at tryCatch (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/regenerator-runtime/runtime.js:63:40)
      at GeneratorFunctionPrototype.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/regenerator-runtime/runtime.js:337:22)
      at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/regenerator-runtime/runtime.js:96:21)
      at GeneratorFunctionPrototype.tryCatcher (/home/pi/node_modules/bluebird/js/release/util.js:16:23)
      at PromiseSpawn._promiseFulfilled (/home/pi/node_modules/bluebird/js/release/generators.js:97:49)
      at /home/pi/node_modules/bluebird/js/release/generators.js:201:15
      at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:197:4)
      at Module._compile (module.js:570:32)
      at Object.Module._extensions…js (module.js:579:10)
      at Module.load (module.js:487:32)
      at tryModuleLoad (module.js:446:12)
      at Function.Module._load (module.js:438:3)
      at Module.runMain (module.js:604:10)
      at run (bootstrap_node.js:394:7)
      at startup (bootstrap_node.js:149:9)
      npm ERR! Linux 4.4.38-v7+
      npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “install”
      npm ERR! node v6.9.2
      npm ERR! npm v3.10.9
      npm ERR! code ELIFECYCLE
      npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: electron-rebuild -e …/…/node_modules/electron-prebuilt
      npm ERR! Exit status 255
      npm ERR!
      npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script ‘electron-rebuild -e …/…/node_modules/electron-prebuilt’.
      npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
      npm ERR! not with npm itself.
      npm ERR! electron-rebuild -e …/…/node_modules/electron-prebuilt
      npm ERR! npm bugs Magic-Mirror-Module-PIR-Sensor
      npm ERR! Or if that isn’t available, you can get their info via:
      npm ERR! npm owner ls Magic-Mirror-Module-PIR-Sensor
      npm ERR! /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
      If i try to run the mirror with the information from the PIR module in the config file, i get the white screen. If i comment out the PIR section in the config.js file, i am able to run the mirror without issue.
      Reply Quote 1
