    Black Screen... I have not upgraded the MM2 system software.
    12 Posts 2 Posters 2.3k Views 2 Watching
    • earnestrichardsE Offline
      earnestrichards
      and it happened… black screen on the Pi4 and MM is still running in the Chrome window on my MacMini.
        sdetweil @earnestrichards
        @earnestrichards cool… so… try running server mode
        npm start server
        and then use chromium browser on the pi4
        i have a config that does all this , i tried to have this as the default setup so one could chnage in config.js and voila… but it wasn’t accepted
        (I do this on pi 0 as electron doesn’t run there anymore)
        down load this file to MagicMirror folder
        https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh
        make it executable
        chmod +x run-start.sh
        edit package. json
        copy the start line
        change the word “start” to “start1”
        looks like this
        "start1": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
        this saves the old start command
        change the right side of the new start to “./run-start,sh”
        looks like this
          "start":"./run-start.sh",
        edit config.js
        and uncomment this line
        set to local
        so it looks like this
        	serverOnly:  "local" ,
        now npm start or pm2 start will launch the MM in server mode (no ui)
        and then launch chromium-browser over it.
        mac still talks to server
        if u need to go back, edit config.js, change serverOnly to false,
        then npm run start1
