    MMM-Tasmota in combination with Sonoff basic r2 and mosquito as broker
    2 Posts 1 Posters 509 Views 1 Watching
    • J
      Jeroen Stap
      I’m running mosquito as broker on the pi. With MMM-MQTTBridge I can properly send and receive messages from my sonoff switches, e.g. when I manually enable the light with the button on the device I can show an alert on the mirror.
      Now I want to add an interface to the screen to be able to show the status of the switch and toggle it from the mirror. For this purpose I wanted to use MMM-Tasmota, however I’m struggling with the configuration, and now I’m even wondering if this module actually supports the sonoff switches or only the sensors.
      for MMM-MQTTBridge I use this in config:
      mqttServer: "mqtt://:@localhost:1883",
      the format for MMM-Tasmota suggests something like this, is that the correct format?
      host: 'http://localhost:1883',
      In logs I do see this: host: 'http://localhost:1883', but I do not see any messages about subscribing to the topic of my sonoff switch for which I configured:
      devices: [
            	topic: "woonkamer/sonoff-nr1",
      	showPowerStats: true
      Should I use a different config?
      (I guess an example file on the github page would be useful).
      • J
        Jeroen Stap
        After some debugging in with npm start dev and checking the console this pointed me to an error in my config; showPowerStats is a global setting, not per device.
        After that it started at least to the point where it would subscribe to the mqtt topic, however I should have considered the obvious; my mqtt structure is not the default suggestion of tasmota, so the code does not correspond with that. Currently trying to adapt for that.
