    No stream output from webcam. No errors raised.
    12 Posts 5 Posters 3.8k Views 5 Watching
    • Y Offline
      yax51 @Axel51
      @Axel51 Thanks! I’ll check it out!
      • Y Offline
        yax51 @hsalas
        @hsalas After thinking about it, I came to the conclusion that it had more to do with the power usage of the raspberry pi than any sort of code/module issue. I noticed I was getting low power notices while just trying to use the webcam. Even using webcamoid would lag, stutter, and give those errors. So I installed Ubuntu 20.04 on a mini desktop, installed MM and the modules (with some tweaking to get pyaudio working) I had no issues, and everything worked perfectly.
        Which means it’s either the pi itself not having enough power, the webcam you are using is drawing too much power, or a combination of both.
        Might be worth exploring
