    MagicMirror server get info through proxy
    4 Posts 3 Posters 872 Views 3 Watching
    • L
      lwvmobile
      Hello,
      Just curious if there was a way to get MagicMirror to retrieve information from servers from behind a proxy. I use a wireless hotspot/PDANet which uses an http/socks proxy to tunnel traffic through. For example, if I use chrome/chromium, I would use
      google-chrome --proxy-server=“socks5://192.168.49.1:8000”
      and I can get through just fine.
      So far, I have tried the following to see if any would work and allow a connection but have had no luck.
      #export http_proxy=http://192.168.49.1:8000/
      #export https_proxy=192.168.49.1:8000/
      #export http_proxy=socks5://192.168.49.1:8000
      #export https_proxy=socks5://192.168.49.1:8000
      cd MagicMirror
      #npm config set proxy socks5://192.168.49.1:8000
      #npm config set https-proxy socks5://192.168.49.1:8000
      npm config set proxy http://192.168.49.1:8000
      npm config set https-proxy http://192.168.49.1:8000
      npm run server
      and just get this output in the cosole when trying to connect though the proxy:
      [2020-11-16 07:36:07.059] [ERROR]  Calendar Error. Could not fetch calendar:  http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics { Error: getaddrinfo EAI_AGAIN www.calendarlabs.com www.calendarlabs.com:80
          at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:56:26)
        errno: 'EAI_AGAIN',
        code: 'EAI_AGAIN',
        syscall: 'getaddrinfo',
        hostname: 'www.calendarlabs.com',
        host: 'www.calendarlabs.com',
        port: 80 }
      [2020-11-16 07:36:08.280] [ERROR]  fatal: unable to access 'https://github.com/MichMich/MagicMirror/': Could not resolve host: github.com
      [2020-11-16 07:36:08.284] [ERROR]  fatal: unable to access 'https://github.com/darickc/MMM-BackgroundSlideshow/': Could not resolve host: github.com
      [2020-11-16 07:36:08.290] [ERROR]  fatal: unable to access 'https://github.com/vincep5/MMM-DarkSkyRadar/': Could not resolve host: github.com
      [2020-11-16 07:36:08.294] [ERROR]  fatal: unable to access 'https://github.com/KirAsh4/calendar_monthly/': Could not resolve host: github.com
      If anybody has had any luck with anything similar, or any ideas, please let me know. Thanks.
        sdetweil @lwvmobile
        @lwvmobile maybe tsocks?
        https://www.binarytides.com/proxify-applications-with-tsocks-and-proxychains-on-ubuntu/
        • L
          lwvmobile @sdetweil
          @sdetweil Sadly, no lock with tsocks or proxychains. I had already attempted proxychains, but I kept getting an error and crash when using that, and tsocks doesn’t crash, but I just get the same errors as above. Pretty sure I’ve got everything configured correctly otherwise in their respective conf files, and I’ve tried a few variations just to make sure.
          Proxychains:
          pi@PI-GW-3BPlus:~/MagicMirror $ proxychains npm run server
          ProxyChains-3.1 (http://proxychains.sf.net)
          > magicmirror@2.13.0 server /home/pi/MagicMirror
          > node ./serveronly
          [2020-11-16 08:25:40.797] [LOG]    Starting MagicMirror: v2.13.0
          [2020-11-16 08:25:40.819] [LOG]    Loading config ...
          [2020-11-16 08:25:40.829] [LOG]    Loading module helpers ...
          [2020-11-16 08:25:40.865] [LOG]    Initializing new module helper ...
          [2020-11-16 08:25:40.867] [LOG]    Module helper loaded: MMM-BackgroundSlideshow
          [2020-11-16 08:25:41.561] [LOG]    Initializing new module helper ...
          [2020-11-16 08:25:41.562] [LOG]    Module helper loaded: newsfeed
          [2020-11-16 08:25:41.639] [LOG]    Initializing new module helper ...
          [2020-11-16 08:25:41.640] [LOG]    Module helper loaded: updatenotification
          [2020-11-16 08:25:41.642] [LOG]    No helper found for module: clock.
          [2020-11-16 08:25:41.643] [LOG]    No helper found for module: calendar_monthly.
          [2020-11-16 08:25:41.894] [LOG]    Initializing new module helper ...
          [2020-11-16 08:25:41.895] [LOG]    Module helper loaded: calendar
          [2020-11-16 08:25:41.896] [LOG]    No helper found for module: currentweather.
          [2020-11-16 08:25:41.896] [LOG]    No helper found for module: weatherforecast.
          [2020-11-16 08:25:41.897] [LOG]    No helper found for module: MMM-DarkSkyRadar.
          [2020-11-16 08:25:41.898] [LOG]    All module helpers loaded.
          [2020-11-16 08:25:42.087] [LOG]    Starting server on port 8081 ...
          [2020-11-16 08:25:42.111] [LOG]    Server started ...
          [2020-11-16 08:25:42.113] [LOG]    Connecting socket for: MMM-BackgroundSlideshow
          [2020-11-16 08:25:42.115] [LOG]    Connecting socket for: newsfeed
          [2020-11-16 08:25:42.116] [LOG]    Starting node helper for: newsfeed
          [2020-11-16 08:25:42.118] [LOG]    Connecting socket for: updatenotification
          [2020-11-16 08:25:42.119] [LOG]    Connecting socket for: calendar
          [2020-11-16 08:25:42.120] [LOG]    Starting node helper for: calendar
          [2020-11-16 08:25:42.121] [LOG]    Sockets connected & modules started ...
          [2020-11-16 08:25:42.122] [LOG]
          Ready to go! Please point your browser to: http://192.168.7.1:8081
          [2020-11-16 08:25:46.112] [LOG]    Create new news fetcher for url: https://www.espn.com/espn/rss/ncf/news - Interval: 300000
          |DNS-request| www.espn.com
          [2020-11-16 08:25:46.305] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
          [2020-11-16 08:25:46.321] [INFO]   Checking git for module: MMM-BackgroundSlideshow
          |DNS-response|: www.espn.com does not exist
          node: ../deps/uv/src/unix/getaddrinfo.c:93: uv__getaddrinfo_translate_error: Assertion `!"unknown EAI_* error code"' failed.
          Aborted
          npm ERR! code ELIFECYCLE
          npm ERR! errno 134
          npm ERR! magicmirror@2.13.0 server: `node ./serveronly`
          npm ERR! Exit status 134
          npm ERR!
          npm ERR! Failed at the magicmirror@2.13.0 server script.
          npm ERR!     /home/pi/.npm/_logs/2020-11-16T13_25_46_466Z-debug.log
          Tsocks:
          pi@PI-GW-3BPlus:~/MagicMirror $ tsocks npm run server
          > node ./serveronly
          [2020-11-16 08:23:12.072] [LOG]    Starting MagicMirror: v2.13.0
          [2020-11-16 08:23:12.094] [LOG]    Loading config ...
          [2020-11-16 08:23:12.107] [LOG]    Loading module helpers ...
          [2020-11-16 08:23:12.145] [LOG]    Initializing new module helper ...
          [2020-11-16 08:23:12.147] [LOG]    Module helper loaded: MMM-BackgroundSlideshow
          [2020-11-16 08:23:12.823] [LOG]    Initializing new module helper ...
          [2020-11-16 08:23:12.824] [LOG]    Module helper loaded: newsfeed
          [2020-11-16 08:23:12.895] [LOG]    Initializing new module helper ...
          [2020-11-16 08:23:12.896] [LOG]    Module helper loaded: updatenotification
          [2020-11-16 08:23:12.899] [LOG]    No helper found for module: clock.
          [2020-11-16 08:23:12.900] [LOG]    No helper found for module: calendar_monthly.
          [2020-11-16 08:23:13.154] [LOG]    Initializing new module helper ...
          [2020-11-16 08:23:13.155] [LOG]    Module helper loaded: calendar
          [2020-11-16 08:23:13.156] [LOG]    No helper found for module: currentweather.
          [2020-11-16 08:23:13.157] [LOG]    No helper found for module: weatherforecast.
          [2020-11-16 08:23:13.158] [LOG]    No helper found for module: MMM-DarkSkyRadar.
          [2020-11-16 08:23:13.158] [LOG]    All module helpers loaded.
          [2020-11-16 08:23:13.349] [LOG]    Starting server on port 8081 ...
          [2020-11-16 08:23:13.377] [LOG]    Server started ...
          [2020-11-16 08:23:13.380] [LOG]    Connecting socket for: MMM-BackgroundSlideshow
          [2020-11-16 08:23:13.381] [LOG]    Connecting socket for: newsfeed
          [2020-11-16 08:23:13.383] [LOG]    Starting node helper for: newsfeed
          [2020-11-16 08:23:13.384] [LOG]    Connecting socket for: updatenotification
          [2020-11-16 08:23:13.386] [LOG]    Connecting socket for: calendar
          [2020-11-16 08:23:13.387] [LOG]    Starting node helper for: calendar
          [2020-11-16 08:23:13.388] [LOG]    Sockets connected & modules started ...
          [2020-11-16 08:23:13.389] [LOG]
          [2020-11-16 08:23:16.623] [LOG]    Create new news fetcher for url: https://www.espn.com/espn/rss/ncf/news - Interval: 300000
          [2020-11-16 08:23:16.823] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
          [2020-11-16 08:23:16.852] [ERROR]  Calendar Error. Could not fetch calendar:  http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics { Error: getaddrinfo EAI_AGAIN www.calendarlabs.com www.calendarlabs.com:80
            errno: 'EAI_AGAIN',
            code: 'EAI_AGAIN',
            port: 80 }
          [2020-11-16 08:23:16.901] [INFO]   Checking git for module: MMM-BackgroundSlideshow
          [2020-11-16 08:23:17.027] [INFO]   Checking git for module: calendar_monthly
          [2020-11-16 08:23:17.052] [INFO]   Checking git for module: MMM-DarkSkyRadar
          [2020-11-16 08:23:17.231] [ERROR]  fatal: unable to access 'https://github.com/KirAsh4/calendar_monthly/': Could not resolve host: github.com
          [2020-11-16 08:23:17.234] [ERROR]  fatal: unable to access 'https://github.com/vincep5/MMM-DarkSkyRadar/': Could not resolve host: github.com
          [2020-11-16 08:23:17.240] [ERROR]  fatal: unable to access 'https://github.com/darickc/MMM-BackgroundSlideshow/': Could not resolve host: github.com
          [2020-11-16 08:23:17.263] [ERROR]  fatal: unable to access 'https://github.com/MichMich/MagicMirror/': Could not resolve host: github.com
          ^C[2020-11-16 08:25:28.626] [LOG]    [SIGINT] Received. Shutting down server...
          [2020-11-16 08:25:28.629] [LOG]    Stopping module helper: MMM-BackgroundSlideshow
          [2020-11-16 08:25:28.630] [LOG]    Stopping module helper: newsfeed
          [2020-11-16 08:25:28.631] [LOG]    Stopping module helper: updatenotification
          [2020-11-16 08:25:28.632] [LOG]    Stopping module helper: calendar
          • D
            dfch @lwvmobile
            @lwvmobile Sorry for the necroposting and late reply, I had similar issue (magicmirror behind http/socks proxy) and couldn’t find any solutions, so with the help of AI I found the issue why tsocks, http_proxy etc env vars don’t work.
            The problem is that MagicMirror overrides the global network layer inside this block using its own new Agent({ connect: { rejectUnauthorized: false } }) constructor whenever self-signed certificates or custom configurations are evaluated [index.js]. This instantly deletes your global proxy settings.
            To fix this, merge your proxy dispatcher into MagicMirror’s option generation scheme so it is safely preserved.
            Fix that worked for me:
            Modify your getRequestOptions() block in /path/to/your/MagicMirror/js/http_fetcher.js to look exactly like this:
            getRequestOptions () {
                            const headers = {
                                    "User-Agent": getUserAgent(),
                                    ...this.customHeaders
                            // 1. Initialize the ProxyAgent using undici
                            const { ProxyAgent } = require("undici");
                            const proxyDispatcher = new ProxyAgent({ uri: "http://192.168.1.1:1080" });
                            // 2. Set the default dispatcher to use your proxy
                            const options = {
                                    headers,
                                    dispatcher: proxyDispatcher
                            if (this.selfSignedCert) {
                                    // 3. Merge the proxy configuration if self-signed cert handling is active
                                    options.dispatcher = new ProxyAgent({
                                            uri: "http://192.168.1.1:1080",
                                            connect: {
                            if (this.auth) {
                                    if (this.auth.method === "bearer") {
                                            headers.Authorization = `Bearer ${this.auth.pass}`;
                                    } else {
                                            headers.Authorization = `Basic ${Buffer.from(`${this.auth.user}:${this.auth.pass}`).toString("base64")}`;
                            return options;
            IMPORTANT: Modify proxy url to the one you use, instead of “http://192.168.1.1:1080”
            It intercepts the raw options configuration object right before MagicMirror wraps it.
            If this.selfSignedCert evaluates to true, it swaps out MagicMirror’s isolated base Agent with a ProxyAgent block that handles both the proxy routing and the SSL bypass rules simultaneously [index.js].
