    Suddenly ipWhitelist no longer working...
    3 Posts 1 Posters 2.2k Views 1 Watching
    • SteffS Offline
      Steff
      Suddenly it is no longer working…
      With the availability of V2.1.0 I did extend my config.js file. After that everything was working until today :( .
      I played a little bit around with further extending the ip range in the config file, but I tend to get permanently following error code:
      Access denied to IP address: 2a02
      From my perspective I did not change anything, however I am slightly surprised that I cannot read a direct ip address like 192.168.178.xx for access denied.
      My ipWhitelist in config.js:
         "ipWhitelist": [
                  "127.0.0.1",
                  "::ffff:127.0.0.1",
                  "::1",
                  "::ffff:192.168.178.1/112"
      The ip address from which I try to access the remote config tool is 192.168.178.25, I am little bit lost, what might the real root cause, so any hint would be highly appreciated…
      • SteffS Offline
        Steff
        Just reverted to a very basic config.js file, which was working definitely beforehand and still get the same error code. Funny thing for me: Regardless from which device I am trying to access the magicmirror, I do get the same error address, so somehow the raspi is not able to resolve to the real ip address, at least this is my impression.
        netstat -lnpt delivers:
        Active Internet connections (only servers)
        Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
        tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN -
        tcp6 0 0 :::8080 :::* LISTEN 2566/electron.js
        tcp6 0 0 :::22 :::* LISTEN - `
        I saw that initially I did not extend correctly my address range, so changed this to:
        ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::ffff:192.168.1.1/112", "::1"],
        I am still lost and I love the remotecontrol module …
        • SteffS Offline
          Steff
          Digging one step further:
          My magicmirror has the ip address 192.168.178.164.
          I am using a cable fritz box, i configured it that this ip address has the hostname “magicmirror”.
          I remember that I had to a reboot of the fritzbox 2 days ago, will investigate whether I potentially lost some settings in the fritzbox.
          Funny thing:
          If I try to access directly http://192.168.178.64:8080/remote.html, I do not get any problem, only if I try to access it with http://magicmirror:8080/remote.html#power-menu
          I do not -yet- understand why…
          BTW: if i ping the magicmirror from the same pc, the address resolving is working:
          PING magicmirror.fritz.box (192.168.178.64): 56 data bytes 64 bytes from 192.168.178.64: icmp_seq=0 ttl=64 time=7.766 ms 64 bytes from 192.168.178.64: icmp_seq=1 ttl=64 time=9.753 ms 64 bytes from 192.168.178.64: icmp_seq=2 ttl=64 time=12.715 ms 64 bytes from 192.168.178.64: icmp_seq=3 ttl=64 time=10.908 ms 64 bytes from 192.168.178.64: icmp_seq=4 ttl=64 time=20.834 ms
          Using the full pseudo domain name `http://magicmirror.fritz.box:8080/remote.html#power-menu’ does not help…
