    Size ratio is not correct
    3 Posts 2 Posters 1.7k Views 2 Watching
    • kusselinK
      kusselin
      Hello everyone, I’m currently building a Magic Mirror. When I connect the Raspi to my 19: 9 TV, the size ratio fits … I connect the pi to the 19 inch monitor (640x480) then everything looks squashed …
      Where do I have to adjust that so that the proportions are correct again?
      Thank you for a message.
      • T
        Tribun
        Hello, you should adjust your screen resolution. Try 1280 x 1024 or higher.
        You can change the setting with “sudo raspi-config” under Display options.
        • kusselinK
          kusselin
          Thank you
