    Force client https with server https already setup
    3 Posts 2 Posters 395 Views 2 Watching
    • K
      KisonHe
      I have a server with MM Server set up ready. I can access it with my browser via https serverd by nginx reverse proxy.
      The problem is when I want to use it on the client, by doing node clientonly --address mymm.xxx.com --port xxx, it says Syntax Error: Unexpected tocken < html>. I guess it is caused by my https redirects. If my reverse proxy recieve http request it will redirect http request to https via 307 code.
      So I changed the --address to --address https://mymm.xxx.com, this time it says http://https://mymm.xxx.com. Well, ok. I guess no way to use https?
      I can start the MM by using Firefox -kiosk option but it is also buggy, can’t promise it will go fullscreen 100%.
      And idea how to run my client with node via https? Or i really have to use the plain http?
        sdetweil @KisonHe
        @KisonHe why use the client? Just launch chromium_browser… see my run_start.sh script here
        for the syntax… I use this on pi0 where electron doesn’t exist.
        K 1 Reply Last reply
        • K
          KisonHe @sdetweil
          @sdetweil Thanks for replying :)
          It seems chromium’s -kiosk option works better than Firefox. When I use Firefox it has quite a chance not actully going full screen. I think my problem is no more now.
