    Error with HelloLucy
    4 Posts 2 Posters 789 Views 2 Watching
      swazi
      Hello,
      I’m getting an error (in the error log code 127) as soon as any audio is captured. The display changes from “Input Command” with a green mic to error.
      I’ve confirmed that my card # and device # match the output from arecord -l. I also was able to create a test wav file with audio using arecord --format cd --duration 15 --channels 1 test.wav
      Any help would be appreciated.
        sdetweil @swazi
        @swazi can u show the log?
          swazi
          The error.log? It only shows the code 127
            swazi
            The main mm log only has basic starting messages and the mm stderr log is empty.
            pi@raspberrypi:~/.pm2/logs $ grep -i lucy mm-out.log
            [2020-12-20 23:10:11.606] [LOG]    Module helper loaded: Hello-Lucy
            [2020-12-20 23:10:12.307] [LOG]    Connecting socket for: Hello-Lucy
            [2020-12-20 23:10:12.308] [LOG]    Starting module helper: Hello-Lucy
            [2020-12-20 23:10:18.859] [INFO]   Checking git for module: Hello-Lucy
