    remotecompliments disappeared - please help
    47 Posts 2 Posters 12.7k Views 2 Watching
    • F Offline
      forjer @sdetweil
      @sdetweil Hmm…is there a simple way to hard code in a RemoteCompiment to force it to show? Just as a troubleshooting step to see it?
      I guess I could consider the default compliments with remote file. Can I run a second default compliment module at the same time? Is it as simple as copying the folders and renaming them “compliments2” or something?
        sdetweil @forjer
        @forjer the default compliments module can be used multiple times without problem. you either pass the compliments as config parms or in a remotefile as config parm
        • F Offline
          forjer @sdetweil
          @sdetweil So are you saying I can run two instances of compliments at the same time, shown in two different locations on the same display? And is this done by copying the compliments.js to make a “compliments2.js”?
            sdetweil @forjer
            @forjer yes, two instances, no need to copy the module
            • F Offline
              forjer
              @sdetweil I’m sorry, I’m a little slow. And this is making my brain hurt. I really appreciate your patience with me.
              How would this look in config.js? And how does it know which compliments go in what position of the MM?
              What I’m after is a normal compliments module running in lower_third, and a second compliments module sliced into 10 time slots with a different set of compliments running in upper_third. I’ve just finished modifying the default compliments.js to get my 10 time slots and that seems to work, so I’m getting closer.
              S F 2 Replies Last reply Reply Quote 0
                sdetweil @forjer
                @forjer modifying?
                no need to modify ( never modify module source code)
                code two modules wherever u want.
                put the compliments text in the config block in config.js
                I am on my phone so everything but the actual compliments
                     module:"compliments",
                     position:"lower_third",
                     config:{
                           compliments:{
                                 same as in defaults section of code
                                 whatever  compliments for module 1
                           OR
                            remotefile:"http://....... somefile on some server"
                     position:"upper_third",
                     config:{
                           compliments:{
                                 whatever  compliments for module 2
                • F Offline
                  forjer @forjer
                  @sdetweil Progress. So I saved a copy of my modified compliments.js into a compliments2 folder as compliments2.js and renamed module.register to compliments2. I then reverted my compliments.js back to original. I then added a compliments2 section into my config.js. And now I have two separate compliments running! I tried that a few hours ago but I must have done something wrong so it didn’t work.
                  In the way you coded it, would I be able to have the ability to run Module 1 with the default time slots (complimentArray) while Module 2 runs a different time slot schedule?
                  Now I think I’d like to get a remotefile set up but I’m guessing I’ll run into some issue with remotefile for my compliments2.
                  • F Offline
                    forjer @forjer
                    @sdetweil Also, is there a way to get my compliments2 to allow time splits at say 11:30 instead of just integer hours? Something like the following?
                    afternoonStartTime: 11:30,
                    afternoonEndTime: 13,
                    It would appear the complimentArray would need to be adjusted by changing “hour” to something else?
                    } else if (hour >= this.config.afternoonStartTime && hour < this.config.afternoonEndTime && this.config.compliments.hasOwnProperty("afternoon")) {
                    	compliments = this.config.compliments.afternoon.slice(0);
                    S 3 Replies Last reply Reply Quote 0
                      sdetweil @forjer
                      @forjer read the doc
                      u can have different remotefiles too
                      https://docs.magicmirror.builders/modules/compliments.html
                        sdetweil @forjer
                        @forjer if u need 10 time slots, then the compliments module would need changing as u might already have done. u should change your own copy, and then use that
                        from the modules folder
                        cp defaults/compliments mycompliments
                        have to change the module register at the top to be the same as the folder name u create on the copy
                        • 4 / 5
