    remotecompliments disappeared - please help
    47 Posts 2 Posters 18.1k Views 2 Watching
      sdetweil @forjer
      @forjer looks like the default time slots are hour based. so another reason to make your own
      • F Offline
        forjer @sdetweil
        @sdetweil Thanks for all of you time and help. You are a wealth of knowledge.
        I’ve only been digging into this thing for a few weeks and I’ve seen so many of your posts helping others. Kudos!
        I like this kind of stuff, I just wish I had better core knowledge so I didn’t spend so much time looking stuff up and tinkering, but I guess that’s one way to learn.
        I have gotten my custom “compliments2” module to work, but still only with integers for time. There’s got to be a simple way to change that. I’ll keep looking.
          sdetweil @forjer
          @forjer said in remotecompliments disappeared - please help:
          what do u mean?
            sdetweil @forjer
            @forjer my son calls me all the time w questions. I don’t know much, but I know how to search, and can usually find an answer pretty quick.
            I do it here too, all the time, writing code, working on install issues. trying to help w modules I don’t know.
            I didn’t know we could run multiple compliments modules concurrently, but I figured it out looking at the code.
            • F Offline
              forjer @sdetweil
              @sdetweil said in remotecompliments disappeared - please help:
              what do u mean?
              I mean that by default, compliments only allows defining “morningStartTime” as 5, but I would like to be able to do is define it as 5:35.
                sdetweil @forjer
                @forjer so, allow the start/end time to be hh:mm
                then check and split if contains ‘:’
                make mins default to 00 if not
                // make starttime always have minutes if specified use them, if not use 00
                config.startTime=config.startTime.inclides(':')? config.startTime, config.startTime+':00'
                and then split (split(':') and convert parts to numbers (parseInt())
                var temp = config.startTime.split(':')
                temp[0] = hours
                temp[1] = minutes
                this.afternoonStartHour = parseInt(temp[0])
                this.afternoonStartMinute = parseInt(temp[1])
                repeat for all your time windows
                then change the code to compare
                might be able to use moment() before()/after() if u build a moment() value from the time slots.
                I think moment has an isBetween()
                https://momentjscom.readthedocs.io/en/latest/moment/05-query/06-is-between/
                google is your friend
                • F Offline
                  forjer @sdetweil
                  @sdetweil I will have to mess with that when I have more time.
                  • 3 / 3
