    remotecompliments disappeared - please help
    47 Posts 2 Posters 18.8k Views 2 Watching
    • F Offline
      forjer @sdetweil
      @sdetweil So are you saying I can run two instances of compliments at the same time, shown in two different locations on the same display? And is this done by copying the compliments.js to make a “compliments2.js”?
        sdetweil @forjer
        @forjer yes, two instances, no need to copy the module
        • F Offline
          forjer
          @sdetweil I’m sorry, I’m a little slow. And this is making my brain hurt. I really appreciate your patience with me.
          How would this look in config.js? And how does it know which compliments go in what position of the MM?
          What I’m after is a normal compliments module running in lower_third, and a second compliments module sliced into 10 time slots with a different set of compliments running in upper_third. I’ve just finished modifying the default compliments.js to get my 10 time slots and that seems to work, so I’m getting closer.
          S F 2 Replies Last reply Reply Quote 0
            sdetweil @forjer
            @forjer modifying?
            no need to modify ( never modify module source code)
            code two modules wherever u want.
            put the compliments text in the config block in config.js
            I am on my phone so everything but the actual compliments
                 module:"compliments",
                 position:"lower_third",
                 config:{
                       compliments:{
                             same as in defaults section of code
                             whatever  compliments for module 1
                       OR
                        remotefile:"http://....... somefile on some server"
                 position:"upper_third",
                 config:{
                       compliments:{
                             whatever  compliments for module 2
            • F Offline
              forjer @forjer
              @sdetweil Progress. So I saved a copy of my modified compliments.js into a compliments2 folder as compliments2.js and renamed module.register to compliments2. I then reverted my compliments.js back to original. I then added a compliments2 section into my config.js. And now I have two separate compliments running! I tried that a few hours ago but I must have done something wrong so it didn’t work.
              In the way you coded it, would I be able to have the ability to run Module 1 with the default time slots (complimentArray) while Module 2 runs a different time slot schedule?
              Now I think I’d like to get a remotefile set up but I’m guessing I’ll run into some issue with remotefile for my compliments2.
              • F Offline
                forjer @forjer
                @sdetweil Also, is there a way to get my compliments2 to allow time splits at say 11:30 instead of just integer hours? Something like the following?
                afternoonStartTime: 11:30,
                afternoonEndTime: 13,
                It would appear the complimentArray would need to be adjusted by changing “hour” to something else?
                } else if (hour >= this.config.afternoonStartTime && hour < this.config.afternoonEndTime && this.config.compliments.hasOwnProperty("afternoon")) {
                	compliments = this.config.compliments.afternoon.slice(0);
                S 3 Replies Last reply Reply Quote 0
                  sdetweil @forjer
                  @forjer read the doc
                  u can have different remotefiles too
                  https://docs.magicmirror.builders/modules/compliments.html
                    sdetweil @forjer
                    @forjer if u need 10 time slots, then the compliments module would need changing as u might already have done. u should change your own copy, and then use that
                    from the modules folder
                    cp defaults/compliments mycompliments
                    have to change the module register at the top to be the same as the folder name u create on the copy
                      sdetweil @forjer
                      @forjer looks like the default time slots are hour based. so another reason to make your own
                      • F Offline
                        forjer @sdetweil
                        @sdetweil Thanks for all of you time and help. You are a wealth of knowledge.
                        I’ve only been digging into this thing for a few weeks and I’ve seen so many of your posts helping others. Kudos!
                        I like this kind of stuff, I just wish I had better core knowledge so I didn’t spend so much time looking stuff up and tinkering, but I guess that’s one way to learn.
                        I have gotten my custom “compliments2” module to work, but still only with integers for time. There’s got to be a simple way to change that. I’ll keep looking.
                          sdetweil @forjer
                          @forjer said in remotecompliments disappeared - please help:
                          what do u mean?
                            sdetweil @forjer
                            @forjer my son calls me all the time w questions. I don’t know much, but I know how to search, and can usually find an answer pretty quick.
                            I do it here too, all the time, writing code, working on install issues. trying to help w modules I don’t know.
                            I didn’t know we could run multiple compliments modules concurrently, but I figured it out looking at the code.
                            • F Offline
                              forjer @sdetweil
                              @sdetweil said in remotecompliments disappeared - please help:
                              what do u mean?
                              I mean that by default, compliments only allows defining “morningStartTime” as 5, but I would like to be able to do is define it as 5:35.
                                sdetweil @forjer
                                @forjer so, allow the start/end time to be hh:mm
                                then check and split if contains ‘:’
                                make mins default to 00 if not
                                // make starttime always have minutes if specified use them, if not use 00
                                config.startTime=config.startTime.inclides(':')? config.startTime, config.startTime+':00'
                                and then split (split(':') and convert parts to numbers (parseInt())
                                var temp = config.startTime.split(':')
                                temp[0] = hours
                                temp[1] = minutes
                                this.afternoonStartHour = parseInt(temp[0])
                                this.afternoonStartMinute = parseInt(temp[1])
                                repeat for all your time windows
                                then change the code to compare
                                might be able to use moment() before()/after() if u build a moment() value from the time slots.
                                I think moment has an isBetween()
                                https://momentjscom.readthedocs.io/en/latest/moment/05-query/06-is-between/
                                google is your friend
                                • F Offline
                                  forjer @sdetweil
                                  @sdetweil I will have to mess with that when I have more time.
                                  • 3 / 3
