    So this just started today
    1 Posts 1 Posters 263 Views 2 Watching
    • M
      mbritt
      I get a blank screen and says it cant reach a site. So I thought I would just restart the MagicMirror and all would be good. When I run the command npm start I get the following error.
      /home/mark/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libnss3.so: cannot open shared object file: No such file or directory
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! magicmirror@2.7.1 start: sh run-start.sh
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.7.1 start script.
      After looking I did an npm audit and npm audit fix. still the same issue.
      Any suggestions to fix this.
      Here is the full log
      1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
      2 info using npm@6.9.0
      3 info using node@v10.15.3
      4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
      5 info lifecycle magicmirror@2.7.1~prestart: magicmirror@2.7.1
      6 info lifecycle magicmirror@2.7.1~start: magicmirror@2.7.1
      7 verbose lifecycle magicmirror@2.7.1~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.7.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/mark/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
      9 verbose lifecycle magicmirror@2.7.1~start: CWD: /home/mark/MagicMirror
      10 silly lifecycle magicmirror@2.7.1~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
      11 info lifecycle magicmirror@2.7.1~start: Failed to exec start script
      12 verbose stack Error: magicmirror@2.7.1 start: sh run-start.sh
      12 verbose stack spawn ENOENT
      12 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
      12 verbose stack at ChildProcess.emit (events.js:189:13)
      12 verbose stack at maybeClose (internal/child_process.js:970:16)
      12 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      13 verbose pkgid magicmirror@2.7.1
      14 verbose cwd /home/mark/MagicMirror
      15 verbose Linux 4.15.0-129-generic
      16 verbose argv “/usr/bin/node” “/usr/bin/npm” “start”
      17 verbose node v10.15.3
      18 verbose npm v6.9.0
      19 error file sh
      20 error code ELIFECYCLE
      21 error errno ENOENT
      22 error syscall spawn
      23 error magicmirror@2.7.1 start: sh run-start.sh
      23 error spawn ENOENT
      24 error Failed at the magicmirror@2.7.1 start script.
      24 error This is probably not a problem with npm. There is likely additional logging output above.
      25 verbose exit [ 1, true ]
