    MMM-SleepWake turn off but not turn on
    mmm-sleepwakemagic mirrorturn onturn off
    23 Posts 3 Posters 9.5k Views 3 Watching
    • K Offline
      krosamont
      Hi. First of all, thanks for your work @sdetweil.
      I wanted to use your module but I don’t know what I did wrong.
      When no motion is detected, I am able to hide the screen but when I move. Nothing happen.
      I am using a Pi Camera module v2.
      I have tried to follow the documentation on your repository:
      1. I have added the module in config.js:
      pi@raspberrypi:~ $ nano MagicMirror/config/config.js
          module: 'MMM-SleepWake',
          config:{
              delay:  0.5,               // default
              mode:  'hide'
              //debug: true
      1. I have made the changes required in motion.conf
      pi@raspberrypi:~ $ sudo nano /etc/motion/motion.conf
      # Command to be executed when an event starts. (default: none)
      # An event starts at first motion detected after a period of no motion defined by event_gap.
      ; on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
      # Command to be executed when an event ends after a period of no motion
      # (default: none). The period of no motion is defined by option event_gap.
      ; on_event_end /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion ended
      Then I have checked if I had correctly installed the motion project and if it worked properly. Everything seems to work:
      pi@raspberrypi:~ $ /var/log/motion/motion.log
      [1865352:motion] [NTC] [ALL] [Jan 18 12:19:13] motion_startup: Using log type (ALL) log level (NTC)
      [1865352:motion] [NTC] [ENC] [Jan 18 12:19:13] ffmpeg_global_init: ffmpeg libavcodec version 58.35.100 libavformat version 58.20.100
      [0:motion] [NTC] [ALL] [Jan 18 12:19:13] main: Camera ID: 0 is from /etc/motion/motion.conf
      [0:motion] [NTC] [ALL] [Jan 18 12:19:13] main: Camera ID: 0 Camera Name: (null) Device: /dev/video0
      [0:motion] [NTC] [ALL] [Jan 18 12:19:13] main: Waiting for threads to finish, pid: YYYY
      [1:ml1] [NTC] [ALL] [Jan 18 12:19:13] motion_init: Camera 0 started: motion detection Enabled
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] vid_start: Opening V4L2 device
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_start: Using videodevice /dev/video0 and input -1
      [0:wc0] [NTC] [STR] [Jan 18 12:19:13] http_bindsock: listening on 127.0.0.1 port XXXX
      [0:wc0] [NTC] [STR] [Jan 18 12:19:13] httpd_run: Started motion-httpd server on port XXXX (auth Disabled)
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_get_capability:
      cap.driver: "bm2835 mmal"
      cap.card: "mmal service 16.1"
      cap.bus_info: "platform:bcm2835-v4l2"
      cap.capabilities=0x85200005
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_get_capability: - VIDEO_CAPTURE
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_get_capability: - VIDEO_OVERLAY
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_get_capability: - READWRITE
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_get_capability: - STREAMING
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_select_input: name = "Camera 0", type 0x00000002, status 00000000
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_select_input: - CAMERA
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_select_input: Device does not support specifying PAL/NTSC norm
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_do_set_pix_format: Testing palette YU12 (320x240)
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_do_set_pix_format: Using palette YU12 (320x240) bytesperlines 320 sizeimage 115200 colorspace 00000001
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls: found control 0x00980900, "Brightness", range 0,100
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls:       "Brightness", default 50, current 50
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls: found control 0x00980901, "Contrast", range -100,100
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls:       "Contrast", default 0, current 0
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls: found control 0x00980902, "Saturation", range -100,100
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls:       "Saturation", default 0, current 0
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls: found control 0x00980918, "Power Line Frequency", range 0,3
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls:       "Power Line Frequency", default 1, current 1
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls: found control 0x0098090e, "Red Balance", range 1,7999
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls:       "Red Balance", default 1000, current 1000
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls: found control 0x0098090f, "Blue Balance", range 1,7999
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls:       "Blue Balance", default 1000, current 1000
      [1:ml1] [NTC] [ALL] [Jan 18 12:19:13] image_ring_resize: Resizing pre_capture buffer to 1 items
      [1:ml1] [NTC] [STR] [Jan 18 12:19:13] http_bindsock: listening on 127.0.0.1 port XXXX
      [1:ml1] [NTC] [ALL] [Jan 18 12:19:13] motion_init: Started motion-stream server on port XXXX (auth Disabled)
      [1:ml1] [NTC] [EVT] [Jan 18 12:19:17] event_newfile: File of type 8 saved to: /var/lib/motion/01-20210118121917.mkv
      [1:ml1] [NTC] [ALL] [Jan 18 12:19:17] motion_detected: Motion detected - starting event 1
      [1:ml1] [NTC] [ALL] [Jan 18 12:19:25] mlp_actions: End of event 1
      [0:wc0] [NTC] [STR] [Jan 18 12:19:25] httpd_run: motion-httpd - Finishing
      [0:wc0] [NTC] [STR] [Jan 18 12:19:25] httpd_run: motion-httpd Closing
      [0:wc0] [NTC] [STR] [Jan 18 12:19:25] motion_web_control: motion-httpd thread exit
      [1:ml1] [NTC] [ALL] [Jan 18 12:19:25] motion_loop: Thread exiting
      [1:ml1] [NTC] [STR] [Jan 18 12:19:25] stream_stop: Closing motion-stream listen socket & active motion-stream sockets
      [1:ml1] [NTC] [STR] [Jan 18 12:19:25] stream_stop: Closed motion-stream listen socket & active motion-stream sockets
      [1:ml1] [NTC] [VID] [Jan 18 12:19:25] vid_close: Cleaning up V4L2 device
      [1:ml1] [NTC] [VID] [Jan 18 12:19:25] v4l2_cleanup: Closing video device /dev/video0
      [0:motion] [NTC] [ALL] [Jan 18 12:19:26] main: Threads finished
      [0:motion] [NTC] [ALL] [Jan 18 12:19:27] main: Motion terminating
      [0:motion] [NTC] [ALL] [Jan 18 12:19:27] motion_remove_pid: Closing logfile (/var/log/motion/motion.log).
      And here is the log when I am using the magic mirror:
      > magicmirror@2.14.0 start /home/pi/MagicMirror
      [18.01.2021 11:49.07.972] [LOG]   Starting MagicMirror: v2.14.0
      [18.01.2021 11:49.08.004] [LOG]   Loading config ...
      [18.01.2021 11:49.08.014] [LOG]   Loading module helpers ...
      [18.01.2021 11:49.08.909] [LOG]   Initializing new module helper ...
      [18.01.2021 11:49.08.916] [LOG]   handler helper in init
      [18.01.2021 11:49.08.917] [LOG]   Module helper loaded: MMM-SleepWake
      [18.01.2021 11:49.08.986] [LOG]   All module helpers loaded.
      [18.01.2021 11:49.09.126] [LOG]   Starting server on port XXXX ...
      [18.01.2021 11:49.09.149] [LOG]   Server started ...
      [18.01.2021 11:49.09.153] [LOG]   Connecting socket for: MMM-SleepWake
      [18.01.2021 11:49.09.153] [LOG]   handler helper in start
      [18.01.2021 11:49.09.157] [LOG]   Sockets connected & modules started ...
      [18.01.2021 11:49.09.535] [LOG]   Launching application.
      [18.01.2021 11:49.09.681] [WARN]  (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false".  It will change to be "true" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
      [18.01.2021 11:49.11.953] [LOG]   sleep-wake helper in socket notification=config
      [18.01.2021 11:49.11.996] [LOG]    external source defined dir=/home/pi/MagicMirror/modules/MMM-SleepWake/motion
      [18.01.2021 11:49.12.005] [INFO]  Checking git for module: MMM-SleepWake
      [18.01.2021 11:49.41.955] [LOG]   sleep-wake helper in socket notification=start_sleep
      [18.01.2021 11:49.41.957] [LOG]   processing start sleep
      [18.01.2021 11:49.41.962] [LOG]   using HIDE approach
      [18.01.2021 11:50.14.012] [LOG]   Shutting down server...
      [18.01.2021 11:50.14.015] [LOG]   handler helper in stop
      I am not able to see what is wrong in my configuration. I hope someone will be able to help me.
        sdetweil @krosamont
        @krosamont remove the ; in motion.conf on the two lines u edited
        no leading ; or #
        • K Offline
          krosamont
          @sdetweil thanks for the quick answer. Sorry I should have payed more attention to this. I have made the modification into motion.conf:
          But it still doesn’t turn on after the sleep…
            sdetweil @krosamont
            @krosamont then u have to restart motion module
            u can test the start/stop commands
            from a terminal window or over ssh
              sdetweil @krosamont
              @krosamont but it sleeps on timer(no motion) and wakes on motion.
              how long after motion til motion fires the ended event?
              look in /var/log/motion.log
              may have to fiddle w some motion settings.
              i changed my time gap down to 15 seconds
              the camera is detecting motion constantly
              • K Offline
                krosamont @sdetweil
                @sdetweil said in MMM-SleepWake turn off but not turn on:
                start/stop commands
                You mean going to the terminal and write:
                pi@raspberrypi:~/MagicMirror $ sudo service motion start
                pi@raspberrypi:~/MagicMirror $ sudo service motion stop
                I have done it. nothing happened
                • K Offline
                  krosamont @sdetweil
                  @sdetweil the default setting is:
                  # Maximum number of frames to be captured per second.
                  # Valid range: 2-100. Default: 100 (almost no limit).
                  framerate 2
                  and I have changed the gap event from 60 to 15:
                  # Event Gap is the seconds of no motion detection that triggers the end of an event.
                  # An event is defined as a series of motion images taken within a short timeframe.
                  # Recommended value is 60 seconds (Default). The value -1 is allowed and disables
                  # events causing all Motion to be written to one single movie file and no pre_capture.
                  # If set to 0, motion is running in gapless mode. Movies don't have gaps anymore. An
                  # event ends right after no more motion is detected and post_capture is over.
                  event_gap 15
                  It sounds good, isn’t it?
                  I have also installed the module again :
                  pi@raspberrypi:~/MagicMirror/modules/MMM-SleepWake $ npm install
                  and I have tried to use your module without using MMM-Face-Reco-DNN…
                  but still I don’t find the solution
                  • K Offline
                    krosamont
                    By the way, I have also noticed that no log are generated in motion.log when I am using the mirror? The log is generated only when I do this command:
                    pi@raspberrypi:~ $ motion
                    Is it normal?
                      sdetweil @krosamont
                      @krosamont motion is a module outside mm
                      u have to run it all the time
                      i think u will have to do
                      sudo motion &
                      to start it
                      K 2 Replies Last reply Reply Quote 0
                      • K Offline
                        krosamont @sdetweil
                        Hello @chanster,
                        How do you run your magic mirror project please?
                        @sdetweil I have tried:
                        Still nothing. And nothing appears in the log. I think this is the problem…
                        If I do:
                        pi@raspberrypi:~/MagicMirror $ sudo motion &
                        Then I get an error and the cam is playing my mirror but there, I have the log!!! :/
                        I think we are close…:face_with_monocle:
                        S C 2 Replies Last reply Reply Quote 0
                        • K Offline
                          krosamont @sdetweil
                          @sdetweil you mean that it’s normal if I don’t see the motion log when I run the mirror?
                            sdetweil @krosamont
                            @krosamont turn off the motion web servers that post video
                            i think there are 4 8080-8083
                            search the conf file
                            • K Offline
                              krosamont @sdetweil
                              I have just found 8080 and 8081…there is no 8083.
                              I have changed them to 0:
                              # TCP/IP port for the http server to listen on (default: 0 = disabled)
                              #webcontrol_port 8080
                              webcontrol_port 0
                              # The mini-http server listens to this port for requests (default: 0 = disabled)
                              # stream_port  8081
                              stream_port 0
                              I have an error when I run:
                              error:
                              [18.01.2021 17:45.26.632] [ERROR] Whoops! There was an uncaught exception...
                              [18.01.2021 17:45.26.640] [ERROR] PythonShellError: mmal: mmal_vc_port_enable: failed to enable port vc.null_sink:in:0(OPQV): ENOSPC
                              mmal: mmal_port_enable: failed to enable connected port (vc.null_sink:in:0(OPQV))0x5b77ac0 (ENOSPC)
                              mmal: mmal_connection_enable: output port couldn't be enabled
                              Traceback (most recent call last):
                                File "modules/MMM-Face-Reco-DNN/tools/facerecognition.py", line 80, in <module>
                                  vs = VideoStream(usePiCamera=True, rotation=args["rotateCamera"]).start()
                                File "/home/pi/.virtualenvs/cv/lib/python3.7/site-packages/imutils/video/videostream.py", line 18, in __init__
                                  framerate=framerate, **kwargs)
                                File "/home/pi/.virtualenvs/cv/lib/python3.7/site-packages/imutils/video/pivideostream.py", line 10, in __init__
                                  self.camera = PiCamera()
                                File "/home/pi/.virtualenvs/cv/lib/python3.7/site-packages/picamera/camera.py", line 433, in __init__
                                  self._init_preview()
                                File "/home/pi/.virtualenvs/cv/lib/python3.7/site-packages/picamera/camera.py", line 513, in _init_preview
                                  self, self._camera.outputs[self.CAMERA_PREVIEW_PORT])
                                File "/home/pi/.virtualenvs/cv/lib/python3.7/site-packages/picamera/renderers.py", line 558, in __init__
                                  self.renderer.inputs[0].connect(source).enable()
                                File "/home/pi/.virtualenvs/cv/lib/python3.7/site-packages/picamera/mmalobj.py", line 2212, in enable
                                  prefix="Failed to enable connection")
                                File "/home/pi/.virtualenvs/cv/lib/python3.7/site-packages/picamera/exc.py", line 184, in mmal_check
                                  raise PiCameraMMALError(status, prefix)
                              picamera.exc.PiCameraMMALError: Failed to enable connection: Out of resources
                                  at PythonShell.parseError (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:254:21)
                                  at terminateIfNeeded (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:129:32)
                                  at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:121:13)
                                  at ChildProcess.emit (events.js:210:5)
                                  at Process.ChildProcess._handle.onexit (internal/child_process.js:272:12) {
                                executable: '/home/pi/.virtualenvs/cv/bin/python3.7',
                                options: null,
                                script: 'modules/MMM-Face-Reco-DNN/tools/facerecognition.py',
                                args: [
                                  '--cascade=modules/MMM-Face-Reco-DNN/tools/haarcascade_frontalface_default.xml',
                                  '--encodings=modules/MMM-Face-Reco-DNN/tools/encodings.pickle',
                                  '--usePiCamera=1',
                                  '--source=0',
                                  '--rotateCamera=0',
                                  '--method=dnn',
                                  '--detectionMethod=hog',
                                  '--interval=4000',
                                  '--output=0',
                                  '--extendDataset=False',
                                  '--dataset=modules/MMM-Face-Reco-DNN/dataset/',
                                  '--tolerance=0.6'
                                exitCode: 1
                              [18.01.2021 17:45.26.642] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                              [18.01.2021 17:45.26.643] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                              [18.01.2021 17:45.49.329] [LOG]   sleep-wake helper in socket notification=start_sleep
                              weird…
                                sdetweil @krosamont
                                @krosamont u have to turn off the servers not set the ports to zero
                                i think the settings are false. on my phone from hospital cant help more. motion doc is pretty good
                                • K Offline
                                  krosamont @sdetweil
                                  @sdetweil I am sorry to hear that. I hope you will have a fast recovery!
                                  I don’t understand which parameters I am suppose to change inside motion.conf
                                  I have also checked the documentation but sorry…I don’t get your point.
                                  Here is the list of all the parameters linked to the HTTP based control :
                                  # HTTP Based Control
                                  #webcontrol_port 0
                                  # Restrict control connections to localhost only (default: on)
                                  webcontrol_localhost on
                                  #webcontrol_localhost off
                                  # Output for http server, select off to choose raw text plain (default: on)
                                  webcontrol_html_output on
                                  #webcontrol_html_output off
                                  # Authentication for the http based control. Syntax username:password
                                  # Default: not defined (Disabled)
                                  ; webcontrol_authentication username:password
                                  # Parameters to include on webcontrol.  0=none, 1=limited, 2=advanced, 3=restricted
                                  # Default: 0 (none)
                                  webcontrol_parms 0
                                    sdetweil @krosamont
                                    @krosamont change the magicmirror port to like 8090
                                    • C Offline
                                      chanster @krosamont
                                      @krosamont said in MMM-SleepWake turn off but not turn on:
                                      Hello @chanster,
                                      I have a script that starts Motion whenever my Rpi restarts :
                                      #!/bin/bash
                                      cd /home/pi/.motion/
                                      sudo motion &
                                      You need to make sure that you are running Motion in the directory where it installed ie “.motion”. If you start motion outside of this directory, it’ll use a generic motion config not your config in the “.motion” directory.
                                      If Motion is detecting motion properly, you see lines like these in your motion log :
                                      event_newfile: File of type 8 saved to: /home/pi/Pictures/motion/02-20210109005258.mkv
                                      The directory where these files are being saved to is what you define in your motion config. Look in that folder to make sure you have files showing up there. If you don’t see any files being saved in that directory, it means Motion is not using your motion config but the generic motion config. Refer to my bolded comments above.
                                      Hopefully this helps.
                                      S K 2 Replies Last reply Reply Quote 0
                                        sdetweil @chanster
                                        @chanster pm2 could start motion on boot too
                                        • K Offline
                                          krosamont @chanster
                                          @chanster @sdetweil Thanks for your help guys.
                                          I understood my problem. I was trying to use facial recognition and motion detection at the same time with 2 different services. I can’t work with MMM-SleepWake and MMM-Face-Reco-DNN at the same time.
                                            sdetweil @krosamont
                                            @krosamont i wanted to try that, never got there
