    MMM-SleepWake turn off but not turn on
    mmm-sleepwakemagic mirrorturn onturn off
    23 Posts 3 Posters 7.6k Views 3 Watching
    • K Offline
      krosamont
      Hi. First of all, thanks for your work @sdetweil.
      I wanted to use your module but I don’t know what I did wrong.
      When no motion is detected, I am able to hide the screen but when I move. Nothing happen.
      I am using a Pi Camera module v2.
      I have tried to follow the documentation on your repository:
      1. I have added the module in config.js:
      pi@raspberrypi:~ $ nano MagicMirror/config/config.js
          module: 'MMM-SleepWake',
          config:{
              delay:  0.5,               // default
              mode:  'hide'
              //debug: true
      1. I have made the changes required in motion.conf
      pi@raspberrypi:~ $ sudo nano /etc/motion/motion.conf
      # Command to be executed when an event starts. (default: none)
      # An event starts at first motion detected after a period of no motion defined by event_gap.
      ; on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
      # Command to be executed when an event ends after a period of no motion
      # (default: none). The period of no motion is defined by option event_gap.
      ; on_event_end /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion ended
      Then I have checked if I had correctly installed the motion project and if it worked properly. Everything seems to work:
      pi@raspberrypi:~ $ /var/log/motion/motion.log
      [1865352:motion] [NTC] [ALL] [Jan 18 12:19:13] motion_startup: Using log type (ALL) log level (NTC)
      [1865352:motion] [NTC] [ENC] [Jan 18 12:19:13] ffmpeg_global_init: ffmpeg libavcodec version 58.35.100 libavformat version 58.20.100
      [0:motion] [NTC] [ALL] [Jan 18 12:19:13] main: Camera ID: 0 is from /etc/motion/motion.conf
      [0:motion] [NTC] [ALL] [Jan 18 12:19:13] main: Camera ID: 0 Camera Name: (null) Device: /dev/video0
      [0:motion] [NTC] [ALL] [Jan 18 12:19:13] main: Waiting for threads to finish, pid: YYYY
      [1:ml1] [NTC] [ALL] [Jan 18 12:19:13] motion_init: Camera 0 started: motion detection Enabled
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] vid_start: Opening V4L2 device
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_start: Using videodevice /dev/video0 and input -1
      [0:wc0] [NTC] [STR] [Jan 18 12:19:13] http_bindsock: listening on 127.0.0.1 port XXXX
      [0:wc0] [NTC] [STR] [Jan 18 12:19:13] httpd_run: Started motion-httpd server on port XXXX (auth Disabled)
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_get_capability:
      cap.driver: "bm2835 mmal"
      cap.card: "mmal service 16.1"
      cap.bus_info: "platform:bcm2835-v4l2"
      cap.capabilities=0x85200005
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_get_capability: - VIDEO_CAPTURE
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_get_capability: - VIDEO_OVERLAY
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_get_capability: - READWRITE
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_get_capability: - STREAMING
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_select_input: name = "Camera 0", type 0x00000002, status 00000000
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_select_input: - CAMERA
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_select_input: Device does not support specifying PAL/NTSC norm
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_do_set_pix_format: Testing palette YU12 (320x240)
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_do_set_pix_format: Using palette YU12 (320x240) bytesperlines 320 sizeimage 115200 colorspace 00000001
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls: found control 0x00980900, "Brightness", range 0,100
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls:       "Brightness", default 50, current 50
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls: found control 0x00980901, "Contrast", range -100,100
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls:       "Contrast", default 0, current 0
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls: found control 0x00980902, "Saturation", range -100,100
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls:       "Saturation", default 0, current 0
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls: found control 0x00980918, "Power Line Frequency", range 0,3
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls:       "Power Line Frequency", default 1, current 1
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls: found control 0x0098090e, "Red Balance", range 1,7999
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls:       "Red Balance", default 1000, current 1000
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls: found control 0x0098090f, "Blue Balance", range 1,7999
      [1:ml1] [NTC] [VID] [Jan 18 12:19:13] v4l2_scan_controls:       "Blue Balance", default 1000, current 1000
      [1:ml1] [NTC] [ALL] [Jan 18 12:19:13] image_ring_resize: Resizing pre_capture buffer to 1 items
      [1:ml1] [NTC] [STR] [Jan 18 12:19:13] http_bindsock: listening on 127.0.0.1 port XXXX
      [1:ml1] [NTC] [ALL] [Jan 18 12:19:13] motion_init: Started motion-stream server on port XXXX (auth Disabled)
      [1:ml1] [NTC] [EVT] [Jan 18 12:19:17] event_newfile: File of type 8 saved to: /var/lib/motion/01-20210118121917.mkv
      [1:ml1] [NTC] [ALL] [Jan 18 12:19:17] motion_detected: Motion detected - starting event 1
      [1:ml1] [NTC] [ALL] [Jan 18 12:19:25] mlp_actions: End of event 1
      [0:wc0] [NTC] [STR] [Jan 18 12:19:25] httpd_run: motion-httpd - Finishing
      [0:wc0] [NTC] [STR] [Jan 18 12:19:25] httpd_run: motion-httpd Closing
      [0:wc0] [NTC] [STR] [Jan 18 12:19:25] motion_web_control: motion-httpd thread exit
      [1:ml1] [NTC] [ALL] [Jan 18 12:19:25] motion_loop: Thread exiting
      [1:ml1] [NTC] [STR] [Jan 18 12:19:25] stream_stop: Closing motion-stream listen socket & active motion-stream sockets
      [1:ml1] [NTC] [STR] [Jan 18 12:19:25] stream_stop: Closed motion-stream listen socket & active motion-stream sockets
      [1:ml1] [NTC] [VID] [Jan 18 12:19:25] vid_close: Cleaning up V4L2 device
      [1:ml1] [NTC] [VID] [Jan 18 12:19:25] v4l2_cleanup: Closing video device /dev/video0
      [0:motion] [NTC] [ALL] [Jan 18 12:19:26] main: Threads finished
      [0:motion] [NTC] [ALL] [Jan 18 12:19:27] main: Motion terminating
      [0:motion] [NTC] [ALL] [Jan 18 12:19:27] motion_remove_pid: Closing logfile (/var/log/motion/motion.log).
      And here is the log when I am using the magic mirror:
      > magicmirror@2.14.0 start /home/pi/MagicMirror
      [18.01.2021 11:49.07.972] [LOG]   Starting MagicMirror: v2.14.0
      [18.01.2021 11:49.08.004] [LOG]   Loading config ...
      [18.01.2021 11:49.08.014] [LOG]   Loading module helpers ...
      [18.01.2021 11:49.08.909] [LOG]   Initializing new module helper ...
      [18.01.2021 11:49.08.916] [LOG]   handler helper in init
      [18.01.2021 11:49.08.917] [LOG]   Module helper loaded: MMM-SleepWake
      [18.01.2021 11:49.08.986] [LOG]   All module helpers loaded.
      [18.01.2021 11:49.09.126] [LOG]   Starting server on port XXXX ...
      [18.01.2021 11:49.09.149] [LOG]   Server started ...
      [18.01.2021 11:49.09.153] [LOG]   Connecting socket for: MMM-SleepWake
      [18.01.2021 11:49.09.153] [LOG]   handler helper in start
      [18.01.2021 11:49.09.157] [LOG]   Sockets connected & modules started ...
      [18.01.2021 11:49.09.535] [LOG]   Launching application.
      [18.01.2021 11:49.09.681] [WARN]  (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false".  It will change to be "true" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
      [18.01.2021 11:49.11.953] [LOG]   sleep-wake helper in socket notification=config
      [18.01.2021 11:49.11.996] [LOG]    external source defined dir=/home/pi/MagicMirror/modules/MMM-SleepWake/motion
      [18.01.2021 11:49.12.005] [INFO]  Checking git for module: MMM-SleepWake
      [18.01.2021 11:49.41.955] [LOG]   sleep-wake helper in socket notification=start_sleep
      [18.01.2021 11:49.41.957] [LOG]   processing start sleep
      [18.01.2021 11:49.41.962] [LOG]   using HIDE approach
      [18.01.2021 11:50.14.012] [LOG]   Shutting down server...
      [18.01.2021 11:50.14.015] [LOG]   handler helper in stop
      I am not able to see what is wrong in my configuration. I hope someone will be able to help me.
        sdetweil @krosamont
        @krosamont remove the ; in motion.conf on the two lines u edited
        no leading ; or #
        • K Offline
          krosamont
          @sdetweil thanks for the quick answer. Sorry I should have payed more attention to this. I have made the modification into motion.conf:
          But it still doesn’t turn on after the sleep…
            sdetweil @krosamont
            @krosamont then u have to restart motion module
            u can test the start/stop commands
            from a terminal window or over ssh
              sdetweil @krosamont
              @krosamont but it sleeps on timer(no motion) and wakes on motion.
              how long after motion til motion fires the ended event?
              look in /var/log/motion.log
              may have to fiddle w some motion settings.
              i changed my time gap down to 15 seconds
              the camera is detecting motion constantly
              • K Offline
                krosamont @sdetweil
                @sdetweil said in MMM-SleepWake turn off but not turn on:
                start/stop commands
                You mean going to the terminal and write:
                pi@raspberrypi:~/MagicMirror $ sudo service motion start
                pi@raspberrypi:~/MagicMirror $ sudo service motion stop
                I have done it. nothing happened
                • K Offline
                  krosamont @sdetweil
                  @sdetweil the default setting is:
                  # Maximum number of frames to be captured per second.
                  # Valid range: 2-100. Default: 100 (almost no limit).
                  framerate 2
                  and I have changed the gap event from 60 to 15:
                  # Event Gap is the seconds of no motion detection that triggers the end of an event.
                  # An event is defined as a series of motion images taken within a short timeframe.
                  # Recommended value is 60 seconds (Default). The value -1 is allowed and disables
                  # events causing all Motion to be written to one single movie file and no pre_capture.
                  # If set to 0, motion is running in gapless mode. Movies don't have gaps anymore. An
                  # event ends right after no more motion is detected and post_capture is over.
                  event_gap 15
                  It sounds good, isn’t it?
                  I have also installed the module again :
                  pi@raspberrypi:~/MagicMirror/modules/MMM-SleepWake $ npm install
                  and I have tried to use your module without using MMM-Face-Reco-DNN…
                  but still I don’t find the solution
                  • K Offline
                    krosamont
                    By the way, I have also noticed that no log are generated in motion.log when I am using the mirror? The log is generated only when I do this command:
                    pi@raspberrypi:~ $ motion
                    Is it normal?
                      sdetweil @krosamont
                      @krosamont motion is a module outside mm
                      u have to run it all the time
                      i think u will have to do
                      sudo motion &
                      to start it
                      K 2 Replies Last reply Reply Quote 0
                      • K Offline
                        krosamont @sdetweil
                        Hello @chanster,
                        How do you run your magic mirror project please?
                        @sdetweil I have tried:
                        Still nothing. And nothing appears in the log. I think this is the problem…
                        If I do:
                        pi@raspberrypi:~/MagicMirror $ sudo motion &
                        Then I get an error and the cam is playing my mirror but there, I have the log!!! :/
                        I think we are close…:face_with_monocle:
                        S C 2 Replies Last reply Reply Quote 0
