    MMM-SleepWake turn off but not turn on
    mmm-sleepwakemagic mirrorturn onturn off
    23 Posts 3 Posters 10.2k Views 3 Watching
      sdetweil @krosamont
      @krosamont motion is a module outside mm
      u have to run it all the time
      i think u will have to do
      sudo motion &
      to start it
      K 2 Replies Last reply
      • K
        krosamont @sdetweil
        Hello @chanster,
        How do you run your magic mirror project please?
        @sdetweil I have tried:
        pi@raspberrypi:~/MagicMirror $ sudo service motion start
        Still nothing. And nothing appears in the log. I think this is the problem…
        If I do:
        pi@raspberrypi:~/MagicMirror $ sudo motion &
        Then I get an error and the cam is playing my mirror but there, I have the log!!! :/
        I think we are close…:face_with_monocle:
        S C 2 Replies Last reply
        • K
          krosamont @sdetweil
          @sdetweil you mean that it’s normal if I don’t see the motion log when I run the mirror?
            sdetweil @krosamont
            @krosamont turn off the motion web servers that post video
            i think there are 4 8080-8083
            search the conf file
            K 1 Reply Last reply
            • K
              krosamont @sdetweil
              I have just found 8080 and 8081…there is no 8083.
              I have changed them to 0:
              # TCP/IP port for the http server to listen on (default: 0 = disabled)
              #webcontrol_port 8080
              webcontrol_port 0
              # The mini-http server listens to this port for requests (default: 0 = disabled)
              # stream_port  8081
              stream_port 0
              I have an error when I run:
              error:
              [18.01.2021 17:45.26.632] [ERROR] Whoops! There was an uncaught exception...
              [18.01.2021 17:45.26.640] [ERROR] PythonShellError: mmal: mmal_vc_port_enable: failed to enable port vc.null_sink:in:0(OPQV): ENOSPC
              mmal: mmal_port_enable: failed to enable connected port (vc.null_sink:in:0(OPQV))0x5b77ac0 (ENOSPC)
              mmal: mmal_connection_enable: output port couldn't be enabled
                File "modules/MMM-Face-Reco-DNN/tools/facerecognition.py", line 80, in <module>
                  vs = VideoStream(usePiCamera=True, rotation=args["rotateCamera"]).start()
                File "/home/pi/.virtualenvs/cv/lib/python3.7/site-packages/imutils/video/videostream.py", line 18, in __init__
                  framerate=framerate, **kwargs)
                File "/home/pi/.virtualenvs/cv/lib/python3.7/site-packages/imutils/video/pivideostream.py", line 10, in __init__
                  self.camera = PiCamera()
                File "/home/pi/.virtualenvs/cv/lib/python3.7/site-packages/picamera/camera.py", line 433, in __init__
                  self._init_preview()
                File "/home/pi/.virtualenvs/cv/lib/python3.7/site-packages/picamera/camera.py", line 513, in _init_preview
                  self, self._camera.outputs[self.CAMERA_PREVIEW_PORT])
                File "/home/pi/.virtualenvs/cv/lib/python3.7/site-packages/picamera/renderers.py", line 558, in __init__
                  self.renderer.inputs[0].connect(source).enable()
                File "/home/pi/.virtualenvs/cv/lib/python3.7/site-packages/picamera/mmalobj.py", line 2212, in enable
                  prefix="Failed to enable connection")
                File "/home/pi/.virtualenvs/cv/lib/python3.7/site-packages/picamera/exc.py", line 184, in mmal_check
                  raise PiCameraMMALError(status, prefix)
              picamera.exc.PiCameraMMALError: Failed to enable connection: Out of resources
                  at PythonShell.parseError (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:254:21)
                  at terminateIfNeeded (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:129:32)
                  at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:121:13)
                  at ChildProcess.emit (events.js:210:5)
                  at Process.ChildProcess._handle.onexit (internal/child_process.js:272:12) {
                executable: '/home/pi/.virtualenvs/cv/bin/python3.7',
                options: null,
                script: 'modules/MMM-Face-Reco-DNN/tools/facerecognition.py',
                args: [
                  '--cascade=modules/MMM-Face-Reco-DNN/tools/haarcascade_frontalface_default.xml',
                  '--encodings=modules/MMM-Face-Reco-DNN/tools/encodings.pickle',
                  '--usePiCamera=1',
                  '--source=0',
                  '--rotateCamera=0',
                  '--method=dnn',
                  '--detectionMethod=hog',
                  '--interval=4000',
                  '--output=0',
                  '--extendDataset=False',
                  '--dataset=modules/MMM-Face-Reco-DNN/dataset/',
                  '--tolerance=0.6'
                exitCode: 1
              [18.01.2021 17:45.26.642] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              [18.01.2021 17:45.26.643] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              [18.01.2021 17:45.49.329] [LOG]   sleep-wake helper in socket notification=start_sleep
              weird…
                sdetweil @krosamont
                @krosamont u have to turn off the servers not set the ports to zero
                i think the settings are false. on my phone from hospital cant help more. motion doc is pretty good
                • K
                  krosamont @sdetweil
                  @sdetweil I am sorry to hear that. I hope you will have a fast recovery!
                  I don’t understand which parameters I am suppose to change inside motion.conf
                  I have also checked the documentation but sorry…I don’t get your point.
                  Here is the list of all the parameters linked to the HTTP based control :
                  # HTTP Based Control
                  #webcontrol_port 0
                  # Restrict control connections to localhost only (default: on)
                  webcontrol_localhost on
                  #webcontrol_localhost off
                  # Output for http server, select off to choose raw text plain (default: on)
                  webcontrol_html_output on
                  #webcontrol_html_output off
                  # Authentication for the http based control. Syntax username:password
                  # Default: not defined (Disabled)
                  ; webcontrol_authentication username:password
                  # Parameters to include on webcontrol.  0=none, 1=limited, 2=advanced, 3=restricted
                  # Default: 0 (none)
                  webcontrol_parms 0
                    sdetweil @krosamont
                    @krosamont change the magicmirror port to like 8090
                      chanster @krosamont
                      @krosamont said in MMM-SleepWake turn off but not turn on:
                      Hello @chanster,
                      I have a script that starts Motion whenever my Rpi restarts :
                      #!/bin/bash
                      cd /home/pi/.motion/
                      sudo motion &
                      You need to make sure that you are running Motion in the directory where it installed ie “.motion”. If you start motion outside of this directory, it’ll use a generic motion config not your config in the “.motion” directory.
                      If Motion is detecting motion properly, you see lines like these in your motion log :
                      motion_detected: Motion detected - starting event 1
                      mlp_actions: End of event 1
                      event_newfile: File of type 8 saved to: /home/pi/Pictures/motion/02-20210109005258.mkv
                      The directory where these files are being saved to is what you define in your motion config. Look in that folder to make sure you have files showing up there. If you don’t see any files being saved in that directory, it means Motion is not using your motion config but the generic motion config. Refer to my bolded comments above.
                      Hopefully this helps.
                      S K 2 Replies Last reply
                        sdetweil @chanster
                        @chanster pm2 could start motion on boot too
                        • K
                          krosamont @chanster
                          @chanster @sdetweil Thanks for your help guys.
                          I understood my problem. I was trying to use facial recognition and motion detection at the same time with 2 different services. I can’t work with MMM-SleepWake and MMM-Face-Reco-DNN at the same time.
                            sdetweil @krosamont
                            @krosamont i wanted to try that, never got there
                            • K
                              krosamont @sdetweil
                              @sdetweil Thanks sincerely for your time and your willingness. I would like to start to fork and try implement modification on some modules but I am not confident enough in Javascript. Do you have any suggestion for me. Where to start? Should I go with nodeJS basic tutorials?
                                sdetweil @krosamont
                                @krosamont thats as good as any place. see my sample module
                                https://github.com/sdetweil/SampleModule
                                • K
                                  krosamont @sdetweil
                                  @sdetweil Thank you for sharing :)
