    MMM-Remote-control all working except for monitor on and off
    12 Posts 3 Posters 4.1k Views 3 Watching
      diemen112 @karsten13
      @karsten13
      ah thank you for your help
      • T Offline
        thobach @diemen112
        @diemen112 @karsten13 For bullseye I needed to change the display driver to the fake kms one (dtoverlay=vc4-fkms-v3d in /boot/config.txt) to have any effect of vcgencmd.
        Afterwards vcgencmd only worked from the host, but not from @karsten13’s docker container. There I ran into the same problem with my MMM-Gestures module:
        [09.10.2022 17:54.49.927] [LOG]   Sun Oct 09 2022 17:54:49 GMT+0200 (Central European Summer Time): exec error: Error: Command failed: vcgencmd display_power 0
        vcgencmd: error while loading shared libraries: libvchiq_arm.so.0: cannot open shared object file: No such file or directory
        I fixed it by mounting two more files from the host, my volume mounts now are:
            volumes:
              - ../mounts/config:/opt/magic_mirror/config
              - ../mounts/modules:/opt/magic_mirror/modules
              - ../mounts/css:/opt/magic_mirror/css
              - /tmp/.X11-unix:/tmp/.X11-unix
              - /opt/vc:/opt/vc/:ro
              - /usr/bin/vcgencmd:/usr/bin/vcgencmd
              - /usr/lib/arm-linux-gnueabihf/libvchiq_arm.so.0:/usr/lib/arm-linux-gnueabihf/libvchiq_arm.so.0
              - /usr/lib/arm-linux-gnueabihf/libvcos.so.0:/usr/lib/arm-linux-gnueabihf/libvcos.so.0
              - /var/run/dbus/system_bus_socket:/var/run/dbus/system_bus_socket
