    MMM-RemoteCompliments-Black Screen
    13 Posts 3 Posters 2.2k Views 3 Watching
      shagtimetim
      https://github.com/electron/electron/issues/1839
        sdetweil @shagtimetim
        @shagtimetim i dont see how you can fix that with a },
          shagtimetim @sdetweil
          @sdetweil Feel free to give it a shot. replace the XXX fields with your personal info:
          /* Magic Mirror Config Sample
          • By Michael Teeuw https://michaelteeuw.nl
          • MIT Licensed.
          • For more information on how you can configure this file
          • See https://github.com/MichMich/MagicMirror#configuration
          var config = {
          address: “localhost”, // Address to listen on, can be:
          // - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
          // - “0.0.0.0”, “::” to listen on any interface
          // Default, when address config is left out or empty, is “localhost”
          port: 8080,
          basePath: “/”, // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
          ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
          // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
          // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
          language: "en",
          timeFormat: 12,
          units: "imperial",
          		module: "alert",
          		module: "updatenotification",
          		position: "top_bar"
          		module: "clock",
          		position: "top_left"
          		header: "US Holidays",
          					symbol: "calendar-check",
          					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
          		module: "compliments",
          		position: "lower_third"
          		module: "currentweather",
          			locationID: "XXX", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          			appid: "XXX"
          		module: "weatherforecast",
          		header: "Weather Forecast",
          			appid: "XXX"
          		module: "newsfeed",
          		position: "bottom_bar",
          			feeds: [
          					title: "Fox News - National",
          					url: "http://feeds.foxnews.com/foxnews/national"
                                                      title: "Fox News - Latest",
                                                      url: "http://feeds.foxnews.com/foxnews/latest"
                                                      title: "ESPN - Headlines",
                                                      url: "https://www.espn.com/espn/rss/news",
          			showSourceTitle: true,
          			showPublishDate: true,
          			broadcastNewsFeeds: true,
          			broadcastNewsUpdates: true
          module: “MMM-awesome-alexa”,
          position: “bottom_bar”,
          wakeWord: “Smart Mirror”,
          clientId: “XXX”,
          clientSecret: “XXX”,
          deviceId: “XXX”,
          refreshToken: “XXX”,
          lite: true,
          isSpeechVisualizationEnabled: true
          module: “MMM-RemoteCompliments”,
          header: “MMM-RemoteCompliments”,
          // See below for configurable options
          if (typeof module !== “undefined”) {module.exports = config;}
