    Current Weather and Weather Forecast looks grey out.
    24 Posts 6 Posters 7.6k Views 5 Watching
    • N Offline
      negrito Project Sponsor
      I need help? What do I need to put in to the custom.css or config.js to get all the in red circled text in white colour, because it looks gray out. Thank you in advance.
      • ? Offline
        A Former User
        This post is deleted!
        • N Offline
          Do I need to specify something about the Current Weather and Weather Forecast? Because only adding that to the custom.css makes no difference it stays gray.
          • ? Offline
            A Former User
            • N Offline
              first of all I would like to emphasize that I really appreciate your help. I’ve tried both, but no change. I cleared the settings for color icons to see if it worked, but nothing. See my custom.css here…
              .newsfeed .small {
              font-size: 30px;
              line-height: 25px;
              .newsfeed .medium {
              font-size: 35px;
              line-height: 30px;
              .clock .date {
              	color: #fff;
              .calendar td {
              color: #fff;
              .calendar .header {
              	color: #fff;
              .MMM-COVID19-SPARKLINE{
                color:#fff;
              .calendar .time {
                color:#fff;
              .normal {
                  color: white !important;
              • ? Offline
                A Former User
                • N Offline
                  Yes, the rest of the custom.css is working an here is the config.js part for that:
                  			module: "currentweather",
                  				locationID: "2754696",
                  				appid: "key removed"
                  			module: "weatherforecast",
                  			header: "",
                  				appid: "key removed",
                  				fade: false
                  • ? Offline
                    A Former User
                    • N Offline
                      I don’t have any reference to the custom.css in my config.js I feel bad al ready:disappointed_face:
                      • ? Offline
                        A Former User @negrito
                          raf
                          /home/pi/MagicMirror/modules/default/weatherforecast/weatherforecast.js
                          in this file change colored from false to true
                            sdetweil @raf
                            @raf please dont edit the code. use config.js
                            • ? Offline
                              A Former User
                                sdetweil @Guest
                                @hango no
                                custom.css is in css always. hard coded to be loaded last
                                never referenced in config.js
                                ? S 2 Replies Last reply Reply Quote 0
                                • ? Offline
                                  A Former User @sdetweil
                                    shagtimetim @sdetweil
                                    @sdetweil Following this: If not in config.js, where do we reference the custom.css?
                                      sdetweil @shagtimetim
                                      @shagtimetim you never reference custom.css.
                                      it is hard coded in the mm runtime to load custom.css last, to allow it to override any styles set before
                                      u have to do nothing
                                        @sdetweil As always, thank you sir.
                                          sdetweil @Guest
                                          @hango altho u can, you shouldnt. there is only one. normal place should be fine
                                          • ? Offline
