    Calendar is ending/hiding "all day event" soon on the day
    7 Posts 2 Posters 1.6k Views 2 Watching
    • P Offline
      Pade2204
      My Mirror is hiding ‘all day events’ very soon on the day of the event.
      Why is that? I would like to have the full day event to stay showing all day on the event.
      Where should I troubleshoot this? Timezone should be ok etc and clock work fine and is set my timezone.
      Any ideas to troubleshoot?
        sdetweil @Pade2204
        @pade2204 edit config.js, add ,“debug”
        to the loglevel array,
        restart mm
        npm start >somefile
        it will show.processing the ics file
        • P Offline
          Pade2204 @sdetweil
          Im not sure where the “loglevel” array is in the config.js
          Do you have an example - thanks :)
            sdetweil @Pade2204
            @pade2204
            logLevel: [“INFO”, “LOG”, “WARN”, “ERROR”], // Add “DEBUG” for even more logging
            • P Offline
              Pade2204 @sdetweil
              I tried to put this into the config file/config loop
              logLevel: [“INFO”, “LOG”, “WARN”, “ERROR”,“DEBUG”],
              • and then npm start, but it gave me a lot of error and the mirror is not starting.
              So I guess this is not for beginners…
                sdetweil @Pade2204
                @pade2204 be careful copy/paste from the forum , it changes the quotes to the wrong type (curved, not straight)
                i just referenced the existing line
                  sdetweil @Pade2204
                  @pade2204 also, as soon as an event starts it is not upcoming. you could turn on showEnd…
                  and split the event into a start and end event, and the end will be an upcoming event all day
