    Google Traffic
    7 Posts 2 Posters 2.3k Views 2 Watching
    • G Offline
      Gr1dL0ck
      google traffic times
      I followed these steps from the webpage
      Navigate into your MagicMirror’s ~/MagicMirror/modules folder
      execute git clone https://github.com/pjestico/MMM-GoogleTrafficTimes.git
      A new folder will be created, please navigate into it. Run npm install in ~/MagicMirror/modules/MMM-GoogleTrafficTimes
      module: ‘MMM-GoogleTrafficTimes’,
      position: ‘top_left’,
      key: ‘my google API’,
      origin: ‘my personal address straight from google’,
      destination1: ‘Work:my work address straight from google’,
      AvoidHighways: false,
      AvoidTolls: false,
      now this exutes fine, but nothing appears???
        sdetweil @Gr1dL0ck
        @gr1dl0ck and this part goes in your config.js modules list, right?
        AvoidTolls: false,
        pleas read the two links in my signature
        • G Offline
          Gr1dL0ck
          yes this is in my Config.js file
            sdetweil @Gr1dL0ck
            @gr1dl0ck and u corrected the local data you needed to supply, yes.
            your google api key for the traffic api
            and your real to and from addtesses
            • G Offline
              Gr1dL0ck @sdetweil
              yes as above
                sdetweil @Gr1dL0ck
                @gr1dl0ck and u enabled all three apis under the same api key
                from the doc
                You will need to enable the following APIs for your key, Maps JavaScript API, Geocoding API, Distance Matrix API.
                • G Offline
                  Gr1dL0ck @sdetweil
                  it was the billing set up preventing it all, i enabled it read its free up to a certain amount of searches, just need to read into it a bit more to see how many times you can use it per month etc without incurring a cost
