    GIT and updates to Weather Module
    5 Posts 3 Posters 1.6k Views 3 Watching
    • crazylegsC
      crazylegs
      Hello! I just need a sanity-check from the smart people on this forum to make sure I understand what I’m doing:
      I’ve built/tested a new Provider for the (new) default weather module. This Provider allows the use of Environment Canada current/forecast weather data on MM. My code also requires a few small tweaks to existing code in the weather module.
      While I’m an (ahem) older Developer, I don’t have a ton of experience with Github, so I just want to make sure I understand the steps to submit my updates to the default weather module. Here’s my understanding of things:
      1. Fork my own copy of the MagicMirror repository into my Github account.
      2. Make my changes - i.e. update the existing modules that need changes plus add my new Provider code
      3. For each module a I change, I need to Commit to the master branch (assuming this is the master for my own forked copy of MM repository)
      4. Once I have made/committed all my changes, I create a Pull Request that outlines what I have done. I assume a single PR will cover all the scripts I am touching?
      5. The PR will be assessed, with maybe questions asked, additional updates requested, whatever. If accepted, my changes in my MM repository will be merged into the main MM repository
      Do I have all this right? Sorry for the newbie questions - just new to this stuff and don’t want to screw up.
      Thanks!
        sdetweil @crazylegs
        @crazylegs almost correct steps.
        the fork is the key, now u have your copy to.modify
        make your own branch for changes
        on master branch (git branch has *next to master)
        git checkout -b your_new_branch_name
        • karsten13K
          karsten13 @sdetweil
          2 more things:
          • the new branch you are using should start on the mm-branch develop (not master)
          • when creating the PR on github you have to manually change the base branch from master to develop
          These rules are specific to the mm-repo. Because of quarterly releases the master branch only changes 4 times in a year. The development between the releases is done on develop.
            sdetweil @karsten13
            @karsten13 thanks forgot develop again!!
            crazylegsC 1 Reply Last reply Reply Quote 0
            • crazylegsC
              crazylegs @sdetweil
              @sdetweil @karsten13
              Thank you both so much for your guidance! It is much appreciated and I believe I understand what I need to do.
