    MMM-DynamicWeather
    problems running mm
    13 Posts 3 Posters 3.8k Views 3 Watching
    • G Offline
      George @scottcl88
      @scottcl88 Hi,
      I reinstalled the module an hour ago on the mirror that has the most modules and the mirror work. :)
      Many thanks!
        Sceetch
        the animations of the modul are always in foreground.
        f.e. If i play a video in fullscren, the clouds in front of it.
        Is it possible to change this?
          scottcl88 @Sceetch
          @sceetch Well that’s what the zIndex option is supposed to, but I don’t believe it works. As an alternative, you can change the opacity to something lower and be able to see through the animations.
          Unfortunately I believe I would need to spend a lot more time re-writing the animations to get the zIndex thing to work. I might try to look into that later, or maybe someone from the community can take a try.
          There is an active issue for that: https://github.com/scottcl88/MMM-DynamicWeather/issues/36
