    My Calendar Woes
    8 Posts 2 Posters 1.1k Views 2 Watching
      Sachin
      Long time user of MM, my calendars have always displayed flawlessly. Since my last update, I can’t seem to display any calendar public or private. I ran PM2 Logs and below is the output. It appears that it can read the IC files but has errors during processing. Any advice would be appreciated!
      0|mm | event={“type”:“VEVENT”,“params”:[],“summary”:“Good Friday”,“start”:“20210402”,“datetype”:“date-time”,“end”:“20210402”,“location”:“United States”,“description”:“Visit https://calendarlabs.com/holidays/us/good-friday.php to know more about Good Friday. \n\n Like us on Facebook: http://fb.com/calendarlabs to get updates",“uid”:"5fc727552b61e1606887253@calendarlabs.com”,“dtstamp”:“2020-12-01T23:34:13.000Z”,“status”:“CONFIRMED”,“transparency”:“TRANSPARENT”,“sequence”:“0”}
      0|mm | [22.02.2021 08:23.26.068] [DEBUG] start=Fri Apr 02 2021 00:00:00 GMT-0500 (Central Daylight Time) end=Fri Apr 02 2021 00:00:00 GMT-0500 (Central Daylight Time)
      0|mm | [22.02.2021 08:23.26.071] [DEBUG] if no tz, guess based on now
      0|mm | [22.02.2021 08:23.26.095] [ERROR]
      0|mm | Whoops! There was an uncaught exception…
      0|mm | [22.02.2021 08:23.26.110] [ERROR]
      0|mm | TypeError: Cannot read property ‘guess’ of undefined
      0|mm | at getCorrection (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:429:31)
      0|mm | at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:378:24
      0|mm | at Array.forEach ()
      0|mm | at Request._callback (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:102:25)
      0|mm | at Request.self.callback (/home/pi/MagicMirror/modules/node_modules/request/request.js:185:22)
      0|mm | at Request.emit (events.js:210:5)
      0|mm | at Request. (/home/pi/MagicMirror/modules/node_modules/request/request.js:1154:10)
      0|mm | at Gunzip. (/home/pi/MagicMirror/modules/node_modules/request/request.js:1076:12)
      0|mm | at Object.onceWrapper (events.js:299:28)
      0|mm | [22.02.2021 08:23.26.126] [ERROR]
      0|mm | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|mm | [22.02.2021 08:23.26.152] [ERROR]
      0|mm | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        sdetweil @Sachin
        @sachin after u did the git pull to update, did u do the npm install to update the dependencies?
          Sachin @sdetweil
          @sdetweil Thanks. Git pull responded with Already up-to-date. I ran NPM install anyway and have the same results.
            sdetweil @Sachin
            @sachin can u remove MagicMirror/node_modules folder, and package-lock.json and then run npm install again.
              Sachin @sdetweil
              @sdetweil Followed your instructions and get a slightly different set of error messages…
              0|mm | ATTENTION: default value of option force_s3tc_enable overridden by environment.
              0|mm | [22.02.2021 11:14.01.081] [ERROR] Whoops! There was an uncaught exception…
              0|mm | [22.02.2021 11:14.01.096] [ERROR] TypeError: Cannot read property ‘guess’ of undefined
              0|mm | [22.02.2021 11:14.01.102] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              0|mm | [22.02.2021 11:14.01.108] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              /home/pi/.pm2/logs/sonos-error-1.log last 15 lines:
              1|sonos | (node:1010) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              1|sonos | (node:1036) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              1|sonos | (node:967) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              1|sonos | (node:972) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              1|sonos | (node:1024) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              1|sonos | (node:958) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              1|sonos | (node:981) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              1|sonos | (node:1004) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              1|sonos | (node:872) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              1|sonos | (node:955) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              1|sonos | (node:889) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              1|sonos | (node:880) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              1|sonos | (node:901) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              1|sonos | (node:854) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              1|sonos | (node:915) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                sdetweil @Sachin
                @sachin weird. same error
                lets try this
                edit ~/MagicMirror/modules/default/calendar/calendarfetcher.js
                change line 17 from
                const moment = require("moment");
                to
                const moment = require("moment-timezone");
                and try again
                  Sachin @sdetweil
                  @sdetweil That was it! Thank you so much!
                    sdetweil @Sachin
                    @sachin wonder why just for you…
                    maybe cause your cal doesnt use tz strings just offsets
