    NYC-Transit MMM Issues
    9 Posts 2 Posters 883 Views 2 Watching
    • N Offline
      Nneuland
      I have no idea what I did. I had it working the other day.
      I tried reinstalling the module, and now the MM can’t ind some folders I think
      I’m getting some errors in terminal after running the mirror and adding the nyc_transit to my config.js. Black screen, cursor visible. Can anyone take a look here and help?
      pi@raspberrypi:~ $ cd ~/MagicMirror
      magicmirror@2.14.0 start /home/pi/MagicMirror
      ./run-start.sh $1
      [30.03.2021 09:10.57.359] [LOG] Starting MagicMirror: v2.14.0
      [30.03.2021 09:10.57.364] [LOG] Loading config …
      [30.03.2021 09:10.57.369] [LOG] Loading module helpers …
      [30.03.2021 09:10.57.371] [LOG] No helper found for module: alert.
      [30.03.2021 09:10.57.512] [LOG] Initializing new module helper …
      [30.03.2021 09:10.57.513] [LOG] Module helper loaded: updatenotification
      [30.03.2021 09:10.57.514] [LOG] No helper found for module: clock.
      [30.03.2021 09:10.57.889] [LOG] Initializing new module helper …
      [30.03.2021 09:10.57.890] [LOG] Module helper loaded: calendar
      [30.03.2021 09:10.57.891] [LOG] No helper found for module: compliments.
      [30.03.2021 09:10.57.891] [LOG] No helper found for module: currentweather.
      [30.03.2021 09:10.57.892] [LOG] No helper found for module: weatherforecast.
      [30.03.2021 09:10.57.895] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘mta-realtime-subway-departures’
      Require stack:
      • /home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js
      • /home/pi/MagicMirror/js/app.js
      • /home/pi/MagicMirror/js/electron.js
      • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
      [30.03.2021 09:10.57.896] [LOG] Loading module helpers …
      [30.03.2021 09:10.57.897] [LOG] No helper found for module: alert.
      [30.03.2021 09:10.57.898] [LOG] Initializing new module helper …
      [30.03.2021 09:10.57.898] [LOG] Module helper loaded: updatenotification
      [30.03.2021 09:10.57.899] [LOG] No helper found for module: clock.
      [30.03.2021 09:10.57.900] [LOG] Initializing new module helper …
      [30.03.2021 09:10.57.901] [LOG] Module helper loaded: calendar
      [30.03.2021 09:10.57.902] [LOG] No helper found for module: compliments.
      [30.03.2021 09:10.57.903] [LOG] No helper found for module: currentweather.
      [30.03.2021 09:10.57.904] [LOG] No helper found for module: weatherforecast.
      [30.03.2021 09:10.57.907] [ERROR] App threw an error during load
      [30.03.2021 09:10.57.915] [ERROR] Error: Cannot find module ‘mta-realtime-subway-departures’
      Require stack:
      • at Module._resolveFilename (internal/modules/cjs/loader.js:798:15)
        at Function…/lib/common/reset-search-paths.ts.Module._resolveFilename (electron/js2c/browser_init.js:7718:16)
        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
        at Module._load (internal/modules/cjs/loader.js:691:27)
        at Function.Module._load (electron/js2c/asar.js:748:26)
        at Module.require (internal/modules/cjs/loader.js:853:19)
        at require (internal/modules/cjs/helpers.js:74:18)
        at Object. (/home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js:8:24)
        at Module._compile (internal/modules/cjs/loader.js:968:30)
        at Object.Module._extensions…js (internal/modules/cjs/loader.js:986:10)
        [30.03.2021 09:10.57.917] [ERROR] Whoops! There was an uncaught exception…
        [30.03.2021 09:10.57.922] [ERROR] Error: Cannot find module ‘mta-realtime-subway-departures’
        Require stack:
        at Object.Module._extensions…js (internal/modules/cjs/loader.js:986:10) {
        code: ‘MODULE_NOT_FOUND’,
        requireStack: [
        ‘/home/pi/MagicMirror/modules/MMM-nyc-transit/node_helper.js’,
        ‘/home/pi/MagicMirror/js/app.js’,
        ‘/home/pi/MagicMirror/js/electron.js’,
        ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
        undefined
        [30.03.2021 09:10.57.925] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [30.03.2021 09:10.57.925] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        [30.03.2021 09:10.58.197] [LOG] Launching application.
        [30.03.2021 09:10.58.228] [WARN] (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently “false”. It will change to be “true” in Electron 9. For more information please check https://github.com/electron/electron/issues/18397
      I hope I did this right. Any thoughts would be greatly appreciated.
      Nick
        sdetweil @Nneuland
        @nneuland you didn’t do the npm install in the module folder
        N 1 Reply Last reply Reply Quote 1
        • N Offline
          Nneuland @sdetweil
          Thank you so much for the response.
          I’m incredibly new. Can this be done through terminal?
          After entering cd ~/MagicMirror/modules, I enter
          git clone https://github.com/Elaniobro/MMM-nyc-transit.git
          To which, I’m informed: fatal : destination path ‘MMM-nyc-transit’ already exists and is not an empty directory
          Could you kindly explain how to initiate an npm install specific to that module?
          If I understand correctly
          Thank you again for your time and assistance
            sdetweil @Nneuland
            @nneuland change into the module folder and do
            npm install
            • N Offline
              Nneuland @sdetweil
              I apologize for my ignorance. How do I do that?
                sdetweil @Nneuland
                @nneuland open a terminal window, just like you did for git clone
                then change to the module folder (just like on windows)
                cd MagicMirror/modules/??? where ??? is the module name
                then once that is the current folder u do
                npm install
                I see the module instructions left out the small detail of changing to its folder after git clone
                • N Offline
                  Nneuland @sdetweil
                  That’s it!! Thank you so very much1
                  The time are off, but that’s a different issue. Thank you so much for your time!!!
                  Really appreciate it.
                  SOLVED
                    sdetweil @Nneuland
                    @nneuland you should read the two links in my signature, they will help. I didn’t write them, just reference good work
                    • N Offline
                      Nneuland @sdetweil
                      Thank you
